Thread: Pumping Station Restoration - Before/After
    Jul 2013
    Phoenix, AZ
    67
    Well, I spent 2 weeks, working 3-4 hours a day doing some restoration work on my pumping station. 10 years in the AZ sun was hard on it. I replaced all the conduit, found/fixed two plumbing leaks, changed out some wiring, replaced all rusty hardware, caulked cracks in the concrete pads and added the river rock. The color is Satin Granite. Still deciding if I should do a repaint the beaten up heater. Also, want to start researching a motor/pump upgrade...G
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Pumping Station Restoration - Before/After
    Wow, nice work!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,288
    What a difference! Lookin good, including the new paint job.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Nice job! Love the rocks to dress it up! You do good work!
    Kim
    May 2015
    Spring Texas
    22
    Nice!
    How did you make the labels?
    Jul 2013
    Phoenix, AZ
    67
    Thanks all! The labels are preprinted. Plumbing Labels, A & A Manufacturing (777704)
