Results 1 to 9 of 9
Thread: Pool wall crack
    Jun 2016
    Lisbon ct
    3
    Pool wall crack
    My liner ruptured over the winter and wall crinkled a little. I'm about to order a new lined and noticed a 3" split where there's a crinkle. I'd there s way to patch the wall? Is it a major issue. The pool is a resin steel that's about 5 years old.
    Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Pool wall crack
    Folks here have repaired that by using a piece of sheet metal on both sides of the wall, pop rivet it all together and use several layers of duck tape to cover the patch on the inside. Welcome.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool wall crack
    Wood has an answer for you above. Could you post a picture?
    Casey's Avatar
    SW PA
    10,461
    Re: Pool wall crack
    Holes are one thing. Cracks are another. Post a pic n let's see it.
    Jul 2014
    Oakbank, Canada
    389
    Re: Pool wall crack
    Most resin pools have a good warranty on them, I would inquire about warranty on it cracking. My concern would be why did it crack?
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2016
    Lisbon ct
    3
    Re: Pool wall crack
    image.jpg[QUOTEt=DarrelB;1044657]Most resin pools have a good warranty on them, I would inquire about warranty on it cracking. My concern would be why did it crack?[/QUOTE]
    Jun 2016
    Lisbon ct
    3
    Re: Pool wall crack
    That's another problem I notices. Atound the base of the pool,?ig looks like it bubbled out. It's abou 15 feet like that., should I be worried?
    thanks
    Casey's Avatar
    SW PA
    10,461
    Re: Pool wall crack
    That looks like frost heave. When the pool wall bulges, it's a high spot in the foundation/base. If it was not like that it is most definitely frost heave and not go away on its own. The pool would need releveled.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Re: Pool wall crack
    I guess I'm not seeing a crack. It looks like a crease from the possible frost heave as mentioned.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
