Results 1 to 8 of 8
Thread: How do I add DE to a sand filter without a skimmer?
    Jun 2015
    Fort Pierce, FL
    129
    I have an Intex 16 ft round ultra frame pool. The pool has one suction and one return. The pool has a skimmer that attaches by hanging it over the side of the pool and using a hose to connect it to the suction. I don't currently have this connected as I am trying to clear the pool and the skimmer had algae so I've washed it and set it aside.
    How can I add DE to my sand filter if I don't have a skimmer? By opening up the filter (removing the valve and unscrewing the clamp) and pouring it on top of the sand?
    Intex 16x48" Ultra Frame AG Swimming Pool 5K gal
    intex 2650 sand filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: How do I add DE to a sand filter without a skimmer?
    You won't be able to monitor your pressure that way. I would either reconnect the skimmer or try to pour it right in front of the suction port in the pool and hope most/all gets sucked in. I have no idea it it would though.
    I just happen to have this right here
    Pool School - Add DE to a Sand Filter
    Jun 2015
    Fort Pierce, FL
    129
    I read that article and that's what made me question how I would do it. I'll hook the skimmer back up today and try it that way. Almost clear and kids birthday party tomorrow so hopefully I can clear it up some more !
    Jun 2015
    Fort Pierce, FL
    129
    How quickly will DE clear a cloudy pool? I'm at shock level on chlorine , brushing 4x a day
    DFW, TX
    24,450
    I don't know, it varies. But, it will help and you are doing the right things to make it happen as fast as possible.
    Jun 2015
    Fort Pierce, FL
    129
    Ok guess I need some POP!
    DFW, TX
    24,450
    LOL, that is always helpful! But, you can't buy it!
    Jun 2015
    Fort Pierce, FL
    129
    I'm nervous that my skimmer may have a permeable bottom, and not all the de went through the hose. Pressure definitely went up so I backwashed but the water has taken on a whitish color. 😳
    Is this normal?
