Thread: How do my numbers look?
    May 2013
    Ottawa, On, Canada
    32
    FC 2.2 - I was sitting closer to 3 but when the temp went up this week it's fallen a bit. I turned up the generator and hopefully should be back to 3 or 4 soon
    CC 0.2 - Looks OK to me
    CYA 80 - I thought I was closer to 40. Good thing I bought some extra R-0013 and tested before I added any extra
    Alk 90 - Looks ok but I don't want to go any higher
    CH 100 - I'm told this is OK for a vinyl pool. Right?
    PH 7.4 - I Had aerated this for 7.2 to 7.6 at the beginning of the year but it's dropped back down again. Is 7.4 ok o should I raise it a bit? Is aeration my only option if I don't want to increase my Alk? Last time it took a week and I needed to leave the solar blanket off so the pool was freezing
    Salt 2900 - The generator recommends 3200 PPM so I might add another half bag and see what happens. Scared to put too much in.
    Anything else I should worry about? In the past, I've had sudden green pools even though I thought I was on top of everything. I'd prefer not to repeat this year.
    27' AG Round (~17000 Gallons or 64000 L)
    Hayward 1.5 HP Power Flo Matrix Pump (2 speed usually run 6hrs high 18hrs low)
    Hayward CC150CAN XStream Cartridge Filter (150 ft^2 120 GPM)
    Hayward AquaTrol SWG
    Installed April 2012
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How do my numbers look?
    It looks like you have a handle on things.
    The pH will rise slowly over time with the TA and SWG. Don't sweat it. The FC level is the one to watch. Better to run a little high than a little low. What's it cost you? A few cents in electricity a month? The pump is running already, right? That's the power hog.
