is adding acid part of normal routine?
I know my TA is still high and I need to try some MA instead of dry acid (been through 16 pounds of that and the pH just goes back up to 7.8+.
dropped to 7.2 (didn't want to go lower as we still swim) and TA dropped from 240 to 200 with dropping pH and aerating using the return.
Back to 7.5+ each day and I keep adding dry acid. At this point, I am going to use Pool Math and add a gallon of MA...
is that routine or only time will tell?
