Thread: Aboveground or Inground Pump
    May 2009
    Lexington, NC
    6
    After doing tons of research and even going so far as getting the permits to have an inground pool installed, have to start all over. Found out from the 4th contractor we had out that the septic tank lines run over the entire part of the yard where the pool was going to go, so back to the drawing board. The only other place a pool will fit is on a 3-4' slope, so considering a semi-inground installation of SunSport's Bermuda model extruded aluminum pool. Trying to figure out the best pump/filter configuration. Not sure if I should be getting an above ground or inground pump since part of the pool will be inground and part above. Also wondering if the pump needs to be self priming. Any suggestions would be greatly appreciated.
    Thanks!
    Christa
    Christa
    17K Gal 18x33 Alum Semi-Inground, 200 sq ft Clearwater II Cartridge Filter, 1 HP Dual Speed Hayward Super Pump
    Guest
    Re: Aboveground or Inground Pump
    The main difference between an inground and above ground pump is whether it is self priming. Whether you need a self priming pump depends on whether the pump will be below the level of the water in the pool or not.
