Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Salt Water Generator Just Died!
    Pennsylvania
    13
    So.... We've had our pool open and it's been sparkling clean. Now our salt water generator decides to die. We're going to be without it for 5-6 days. That means the pump can't run. Any ideas of how to try to keep the pool from turning into a swamp?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Re: Salt Water Generator Just Died!
    Bleach. Doesn't matter if it's made poolside or at some huge factory somewhere and bottled up in plastic jugs. Same stuff.
    Use the bleach setting on poolmath and pour it in front of a return jet. Problem solved. Unless the pump died, too. Then break out the brush and keep things mixed.
    Jun 2014
    15,194
    Not sure what kind of equipment you have since your signature doesn't list your pool & equipment, so I'm assuming this is a pump/SWG combo? No way to bypass it to leave the pump on only? If not, at least slowly add some regular bleach to the water and brush it around to maintain that FC. That should give you a little breathing room until you can get the system running again. You can always add bleach as much as needed, just make sure to manually get it mixed around.
    Pennsylvania
    13
    No pump. Our SWG runs our pump. I have the Aquabot in there but I doubt it's going to do much.
    Oct 2015
    Katy/Texas
    411
    Use pool math to determine how much bleach to pour in.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Pennsylvania
    13
    Quote Originally Posted by WASP View Post
    How often do you think I'll have to bleach it in the next 5-6 days?
    May 2016
    Navasota, Tx
    76
    I'm new but from what I gather 1/2 gallon per day should get you by. It's a loaded question with no pool info in your sig though.
    Brett
    23'x32' Inground Free Form Gunite. 7' Raised spa, Jandy equipment, Aqualink, Stonescape with Abalone shells
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Why can't the pump run?
    Pennsylvania
    13
    Quote Originally Posted by rustyshakelford View Post
    Brett
    We have a fiberglass pool. 18 ft wide X 44 ft long, 8ft deep. I'm not sure how many gallons it is.
    Quote Originally Posted by JohnT View Post
    The pump is powered by our salt water generator. It is dead. We have taken it apart and have to ship it to Florida for repair /rebuild.
    May 2016
    Navasota, Tx
    76
    Usually the swg runs when the pump runs. Just because the swg isn't working doesn't mean the pump can't still work. If you need to replace the section of pipe where the swg usually is I would consider that before letting my pool sit stagnent.
    Brett
    Pennsylvania
    13
    The panel that powers the SWG and pump has been removed. I don't see any way we can get power to the pump.
    Fiberglass
    18 X 44, 8ft deep
    Salt water
    Jun 2014
    15,194
    Something you might consider in this unusual situation is renting a submersible pump. That way you could at least keep water and chemical moving until you can find a more permanent solution. It's been done before.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Add bleach to maintain FC at target for your CYA, Chlorine CYA Chart, and brush daily.
    Pennsylvania
    13
    Quote Originally Posted by Texas Splash View Post
    We need to look into that, for sure. I have our Aquabot in now. I figured some water movement was better than none.
    Fiberglass
    18 X 44, 8ft deep
    Salt water
    DFW, TX
    24,502
    Just add enough bleach each day to raise FC to target for your CYA, Chlorine CYA Chart and then brush the pool to mix it up.
    Is it an AutoPilot DIG220?
    What's left on the wall?
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    Mod note: Two threads merged. Please only open one thread per problem. Thanks!
    DFW, TX
    24,502
    I thought I answered that question twice!
    Pennsylvania
    13
    Sorry about that! Wasn't sure where to post it.
    Fiberglass
    18 X 44, 8ft deep
    Salt water
  20. Back To Top    #20
    Pennsylvania
    13
    Quote Originally Posted by JamesW View Post
    Nothing. There's no way to get power to the pump without the SWG.
    Fiberglass
    18 X 44, 8ft deep
    Salt water
