Thread: How Precisely Do You Measure CYA?
    Jul 2015
    Pittsford, NY
    32
    I understand that the CYA test is the most 'subjective' of all the tests, but how specifically do you guys measure it? There is a decent range from JUST when you begin to see the black dot disappear, to when the black dot is completely invisible. What is the standard way of measuring? Thanks!
    Sep 2015
    Rome, NY
    363
    Re: How Precisely Do You Measure CYA?
    Great question.
    I swear my eyes and mind play tricks on me.
    Just when I think it is gone my mind tells me it is there.
    May level is probably wrong
    Put your pool and setup info in your signature. It will help in the long run.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    38,537
    Try the standard CYA solution and at 50ppm that is what it should look like. The dot should be completely gone.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,668
    Pour to the first line (100) GLANCE in, if you still the dot then pour to the second line and GLANCE in, if you still see the dot...keep on like this until you do NOT see when you GLANCE in. Do NOT stare or you will end up seeing the dot LOL
    Kim
    Sep 2015
    Rome, NY
    363
    you're right Kim...you will see it if you stare LOL.
    Guess I better check again tomorrow, especially after all this rain!
