Results 1 to 7 of 7
Thread: Bleaching new 22x52 pool
    May 2016
    JAX Fl
    4
    I have just finished setting up my intex 22'x52" 10,500gallon pool. Its still has a few days left to fill but im wondering about how to treat it when its full. I purchased the SWG with it and im going to pick up the recommended amount of salt for the pool. I know the salt needs to dissolve and that the SWG is slow to produce the base FC.
    I ordered a TF-100 test kit but that wont be here for another week. So im planning on adding bleach to the pool when its full and then CYA and then the 260lbs of salt. From what I can figure from pool math I should add about 80oz of bleach and 100oz powdered CYA. How far off are my numbers?
    30,413
    Re: Bleaching new 22x52 pool
    Welcome to the forum.
    TFTestkits takes great pains to make sure every order goes out the same day it is ordered. It is two days UPS delivery to Jacksonville, FL.....are you sure about that "next week?
    May 2016
    JAX Fl
    4
    Thanks for the welcome. This is a great forum from everything I see.
    I did however order the test kit form a different company. Tftestkits was showing they were on backorder.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,149
    The TF-100 is NOT on back order-the Speedstir was on back order, but they have arrived!
    May 2016
    JAX Fl
    4
    Thanks for the info but I have already purchased one. But back to the main issue...
    30,413
    What are your current test results? We have to have a baseline to get you started.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Once the water is circulating, you want to get FC to 3. That's target for no CYA. That's a little over a quart of bleach.
    You did poolmath right -- 100 oz of CYA granules is the right dose to get up to 70 CYA. You can mess around with the sock and get that in the water.
    Beyond that, you're stalled without a test kit. You need to test to adjust pH and TA as needed (Pool Store tests are not a sufficient substitute!) and also test and adjust FC every day, with the FC target rising as the CYA dissolves. You can estimate the CYA level by how much is left in the sock. Just remember yours is a bleach pool initially so use that FC target. But remember, without a test kit, you don't know where you are on FC so you can't figure out how much more bleach you need to add!
    You might be wisest to only add half the CYA now and just add the 3 FC every day until you can test!
    Once everything is balanced and swimmable, then you add salt and let that dissolve. Lastly you turn on the SWG. With a test kit, two days after full. Without a test kit, who knows? If it goes green on you, it could take weeks.
