Thread: Pool pump turns off after a couple hours
    Jun 2016
    Alton, IL
    1
    Unhappy Pool pump turns off after a couple hours
    This is the first time opening the pool. I moved into a home and the owner had this above ground pool for ten years. It is a 24 ft pool. It has a sand filter. The first problem i had was the motor. It was shot. I then got another motor and everything was working fine, but now it is randomly turning off. When i turn it back on, dirty water will shoot out of the jet inside the pool for about 30 seconds or so and then clear up. I am a beginner and have no idea what I am doing.
    pool: 24 ft above ground pool, sand filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pool pump turns off after a couple hours
    Welcome to TFP!
    What is the pressure on you filter now? And when backwashed?
    When is the last time you cleaned the filter?
    How about the pump basket, is it clean?
    This might be handy, Pool School - Maintenance and Cleaning of Pool Filters
    Do some reading in Pool School
    Pool School - Getting Started
