Results 1 to 9 of 9
Thread: Intermatic Timer - crapped the bed!
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    Just went outside to continue painting the pool house when I noticed the filter wasn't running..
    After checking all "fuses" turning on and off main power, I now know the clock motor in the timer is dead.. or the whole thing-
    The override switch isn't allowing the filter to turn on either..
    I think I need to buy a new timer. Lowe's only available for delivery. Any thoughts?
    Should we continue with this type of timer?
    I need to get my filter running asap. I do hope it is just the timer and not the filter motor as well. (My husband just texted me that the power went out this morning for a few minutes)
    Any advice please and thank you
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG ( to be installed 06/2018)
    Aug 2013
    Oklahoma City, OK
    140
    Re: Intermatic Timer - crapped the bed!
    Can you hear the timer running? You should be able to hear if you put your ear close to it
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Jul 2014
    Ottawa Ontario
    56
    Home Depot also carries Intermatic timers. Have you tried there?
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    I forgot about HD. Will try them! I can hear a slight hum.. but the time is not changing. I thought I used to hear it ticking.
    Aug 2013
    Oklahoma City, OK
    140
    Yes it should tick for sure
    30,421
    Really? I don't think my intermatic does
    I don't know if yours is the same model Intermatic as mine, but I had a devil of a job removing the mounting screws, to the point where I posted on TFP to make sure I was in fact removing the retaining screws. It was straightforward once I got confirmation that I was proceeding correctly.
    How does the pesky timer motor come out??
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    I think my timer is running.. when I just rebooted the main power again, I hear"electricity" running in the timer. Waiting to see if the time thing moves enough to see that it works.
    I am afraid that my filter has died. I have a 1hp USQ1102 MOTOR.
    How do I check it out to see if that is what has died? I would hate to call the pool company. Oye
    Aug 2013
    Oklahoma City, OK
    140
    Maybe not? I cant always hear a tick from my intermatic. I could be wrong, it wouldnt be the first time!
