Results 1 to 7 of 7
Thread: Opening a swampie pool. I read Pool School...
    May 2016
    ozark, al
    3
    I went to work on my pool last week and realized that my cartridge filter pump was bad. Just got the new one in today and I'm ready to get started. I just need some help. I read pool school and sparkling oasis but there isn't a ton of info (that I could find) about how those treatment plans affect SWGs and if they should be running during SLAMs. My SWG has a pretty nasty algae bloom inside of it :S. I'm pretty new to all this and just winged it last year. Any advice (or step-by-step instructions) would be so appreciated! Also, somehow all my test strips bleached out so I've got to get new ones but we're starting from zero maintenance all winter.
    16ft x48in round, above ground with a SWG.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Opening a swampie pool. I read Pool School...
    Welcome!
    I wouldn't bother with guess strips, they are near worthless. There is a link in my sig for TFTestKits. Order one of those or a Taylor 2006C today, then we can get going.
    SWG are turned off for SLAMs.
    How's the water look now? e: It's in the title. Swampy. Add a half bottle of bleach every day until you get your test kit.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    +1 to ordering a TF100 from TFTestkits.net. Get the XL size for your SLAM.
    Scoop, brush and add 1/2 jug of bleach daily while you wait for your kit.
    And read up, Pool School - SLAM - Shock Level And Maintain
    May 2016
    ozark, al
    3
    So what's the difference between test strips and kits?
    Also, I could use some clarification on the bleach thing. I know there is liquid chlorine, is that what y'all are referring to?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Test strips are (nearly) useless, a proper test kit will have you testing all the things that are important to keep your pool TFP sparkly.
    Clorox, Great Value bleach or 10% Chlorinating Liquid from Wal-Mart, yep!
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    459
    The active ingredient in beach = Sodium Hypochlorite = Liquid chlorine.
    The only variables are strength, price, and volume. Regular Clorox is between 3-6%, Concentrated Clorox is 8.25%. Both can be found in 121 oz. "gallon" jugs. "Liquid chlorine" typically ranges in strength between 10% and 12.5% (as stated on the bottle), but can be found in true 128 oz. gallon jugs or larger.
    To save on cost, you don't always have to use name brand. You can use generic, just not anything with additives (i.e. scented or spashless). Regarding price, there is a thread discussing where one can find current year deals. there is also a link that will break down cost per active oz.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    May 2016
    ozark, al
    3
    Thanks, y'all!
