Results 1 to 12 of 12
Thread: Holding FC better than I expected
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    This may be long but want to give all pertinent info, so try to bare with me:
    After opening my pool this season, I quickly discovered that my Salt cell has ran it's life expectancy. BUT before I knew it was bad, the salt was reading too low according to the automated board for the SWG to work (which I expected as I drop about 8" of the water for the winter and then refill for the spring). So I added 5 bags (200lbs) of salt. The board was reading only 2600 after. Still too low for the system to work. I thought: "Wow. I must have dropped more water than I thought prior to closing". So I added another 5 bags which would be the correct calculation to go from 2600 - 3200. At this point my cell was reading only 2800. High enough for it to kick on and actually produce chlorine. But clearly inaccurate according to hand calculations. At this point I manually tested the salt. One test showed 4500, another 4000. Based on what I typically know I need to add and what I actually did, I think the 4500 is more accurate.
    So I brought the cell to Leslies and had it checked out - It failed. I ordered a new cell, which should be here Tomorrow..... In the meantime I had some water adjusting to do. Because when the new cell gets here and hopefully reads proper, it will not work if it is reading too high of salt. So I dumped water. LOTS of it. Luckily I had yet to bring my Calcium and CYA back to proper levels. If I did I would have just dumped them in the woods too. So out with about 10" of high salt water and in with new fresh water. Obviously, the bad SWG was producing no Cl at this time, so I dumped a gallon of 8.3% bleach into pool while filling back up on Sunday. (if you are still with me, thanks)
    Monday early afternoon: Pool high enough to get the skimmers going, so I started the CYA in sock routine. But only added 1/3 of what I needed to get to required amount. I also dumped a gallon of bleach in for good measure.
    Monday night: Pool now full, I checked FC levels - it was 5.0. Sounds about right as Monday was somewhat cloudy. But I really didn't have much CYA dissolved either at this point. Added another 1/3 of my CYA to socks and let pump run. no more bleach.
    Now for the bizarre part:
    Tues night: First I checked my CYA socks. Contents were fully dissolved. GREAT - I'm getting there. Next I checked FC again. 5.0. Sucker was still holding after another day of full sun, no more bleach, and only about 2/3 the CYA added. At this point I added the remainder CYA to the socks but no more bleach.
    Wed night (Last night) I checked the socks. CYA was fully dissolved. So I figure time to test it. Now I hate this CYA test. I feel it is extremely inaccurate and totally subjective as to when that lousy dot actually disappears. It was dusk unfortunately, so not the best of conditions to test in. I tried under a few different lights and can conclude it is definitely greater than 50 but less than 80. (I want to target 70). Anyway, close enough for now till I can try again in the sun.
    Other results from last night:
    pH = 7.2
    TA = 70
    FC = 5.0 (maybe a tad less, but certainly not 3.0) Call it 4.0. Either way I cannot believe how well this pool has held CL for over 2 days (55 hours) of no bleach dosing, of which the first day had virtually no CYA to speak of yet.
    What's your guys' take on all of this?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Aug 2010
    Dallas, TX
    4,052
    Re: Holding FC better than I expected
    How are you measuring FC?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Five drops of R-0001, followed by 5 drops of R-0002. Cap, shake, hold up to a white cloud, compare color.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    That is weird. Is there a cover on the pool? Maybe add a couple ppm and check again.
    Do you have an FAS/DPD chlorine test to double check? That is the best one. But, the DPD test you have is fine too.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    no cover and no FAS/DPD. This is what I have always used. Never felt the need to upgrade as I have never had the more common problem of not being able to hold Cl. The only reason I am so on top of this right now if because of the bad salt cell. When my cell is working I don't go crazy testing every night like this. I guess if there's a "problem" to be had, this is a good one.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I'm pretty sure the highest FC result using the drop test is 5, so you might have had more than 5 and it drifted down and you are still at 5. Best to order the FAS/DPD powder test so that you have a better, more accurate result. It is easy to overshoot your FC is you have really fresh bleach which can be stronger than the amount listed on the label or if overestimate your pool size.
    You can order one from here: TFTestkits.net
    I love the speed stir and wish I would have purchased one sooner: TFTestkits.net
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by kcindc View Post
    Yep, that's where I was headed. You were well over 5.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I had a feeling that might have been it. So on my kit the red at 5.0 is the same as say the red at 8.0, or 25.0 even? Said another way, no matter how high my FC gets, the red won't get any darker than the highest mark on the vial?
    Is this correct?
    Aug 2010
    Dallas, TX
    4,052
    That's correct. That is why we use the FAS-DPD. You can't measure over 5 with what you have.
    Sep 2015
    Reisterstown, MD
    5
    Out of curiosity can you fill tube on DPD test half pool water and half distilled, do the drops and then double the reading? Example: True FC is 8. Will half and half give a reading of FC 4 and then you double it to have true FC 8?
    23000 gal. IG colored plaster 18x38 rectangular pool with jacuzzi in the corner. Purex Triton FNS Plus 48 DE filter. Taylor (high) test kit.
    Centurion pump model# 7-168887-06. Built 2001 and filled from a well since then.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I love an outside the box thinker. I wonder if that works. If not, it would be good to know if there is a way to trick the test into reading a higher Cl level on a DPD test. I know you can't get the ultra high readings. But if you are running a little over the max of 5.0 on a DPD test and that's all we have, it would be helpful.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    I should interject her to mention that at really high FC levels, the DPD reagent bleaches out.
    The OTO (yellow) FC test goes through different shades from pale yellow to blinding tweety bird yellow to school bus (Or Caterpillar equipment) yellow to hunter orange to pumpkin orange and into shades of brown. But none of them are really accurate.
    The FAS-DPD powder and drops will measure up to 50 FC with as much as .2 resolution. If you have the patience for that many drops. You can buy just the FAS-DPD add-on here
