Results 1 to 14 of 14
Thread: pH is 8.6-Can't bring it in range-Not sure what to do next
    May 2013
    New Jersey
    77
    Hi, I opened my pool last Friday. It was unusually dirty with a large dark stain at the Bottom. I remember last year starting off with 15 gallons of 8.25% bleach and that didn't raise the chlorine much....I added a few more gallons, few more etc. and finally got it in range. I decided this year with it being so dirty I would just dump 30 gallons in. It cleared within 2 days and the water is crystal clear, stain gone however my TA is of course high now.
    I had the water tested yesterday:
    CYA-0
    TC-3.6
    FC-3.6
    PH-8.6
    TA-0
    TH-291
    The pool place suggested adding 54lbs of baking soda, 9lbs of PH reducer, 6lbs stabilizer. I decided I would try getting the PH where it needs to be first so I added a gallon of Muriatic acid. Tested the water. PH Still off the chart. So I added another 1/2 gallon MA and still the PH today was off the chart, def in the 8+ range.
    Is it because my chlorine level is too high? Should I start adding the baking soda to get my TA up? Not sure what to do next.
    Installed 2005. Rectangular 20' x 40' 27,000 gal. Gunite, 3M quartz plaster finish, Hayward 4 cartridge filter, Hayward 2hp pump, Raypak 400,000 BTU Cupro-Nickel heater (2014) CoverPools safety cover, Using TFP bleach method.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: pH is 8.6-Can't bring it in range-Not sure what to do next
    After 3 years I think it's time to get a proper test kit
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2010
    Dallas, TX
    4,052
    And ignore the pool store.
    FC of 3-4 is not going to affect the pH test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Those test results are nonsense. Your pH wouldn't be that high with no TA.
    Adding a bunch of baking soda will just drive the pH higher and it's already off the scale.
    The test block stops at 8.2 (If you're using your own) so you could be at 8.2 or 8.3 or just as easily at 9.0. Remember the pH scale is logarithmic. It's the exponent value. The drop from 9 to 8 is 10 times as large as the drop from 8 to 7, so it will use huge amounts of acid to shift it. You've just discovered that. Once it comes into range, the quantities will come down.
    May 2013
    New Jersey
    77
    I tested the water as well with a new PH test kit and it is very high. The color was no where near the 8.2 top marker. I thought it was odd that the pool store analysis stated my TA is 0 though. (waiting for a better test kit so I can test TA as well) So, you think I should just let the chlorine level settle down for another day or so and test again? Definitely holding off on adding any baking soda. Should I add more Muriatic acid? BTW, is there a difference between Muriatic acid from HomeDepot or the pool store?
    I have an automatic safety cover which is usually always closed. I'm leaving it open for now and have been running the pump non-stop.
    Richard320's Avatar
    Jan 2010
    19,075
    You have at least a minimal test kit that checks pH, so get that down between 7.2 and 7.8 using acid.
    Chemically, there's no difference between MA from the pool store or Home Depot. Pricing will likely be much different. DO look at the strength, though. Sometimes the hardware stores sell "safe" or "low-fuming" acid which is half strength. In which case, the pool store's will likely be a better value.
    Get a complete test kit coming, so you can take control. You may need some CYA, or you may have too much. Pool store's always get that one wrong. Bonus: the TF100 comes with a 5t0 CYA standard solution so you can practice the test and see how to get the right readings. Then when you test, you'll know your number is right.
    And make sure you keep chlorine in that pool while you're messing with the pH. You don't want an algae bloom while you're waiting for your test kit.
    May 2013
    New Jersey
    77
    Thanks Richard. Your right, My local HD stopped carrying muriatic acid for the last few years. I remember them telling me it was too dangerous for the general consumer here in NJ. Sparklers and sling shots are too dangerous as well here as they are illegal too. Don't get me started....
    I was surprised to see they have it again but I just looked at the empty container and it is low-fume, has very little smell at all. Maybe that's why my PH hasn't moved much. I'll get a gallon from the pool store to have on hand. And yes, algae has snuck up on me in previous years trying to get the initial water balance. Thanks for the reminder!
    May 2013
    New Jersey
    77
    May 2013
    New Jersey
    77
    I got a better test kit which included TA and my TA is 140. My PH is low now. If I had added all the chems the pool place suggested my chemistry would have been totally out of whack.
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by petes914 View Post
    Low pH and high TA is a good combination. All you need to do to raise pH is some aeration. Anything to break the surface and get some bubbles and ripples going. No chemicals needed.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    This is why we tell folks that buying a quality test kit is the best thing you can do for your pool.
    Support the site
    Nov 2013
    Fort Worth, TX
    114
    I buy muriatic acid from HD all the time. The one I buy is definitely NOT low fume and brings my PH and TA down nicely. In my store, the acid is just outside near the pavers, etc. on a pallet.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    May 2013
    New Jersey
    77
    Quote Originally Posted by Billrector View Post
    Hi Bill, yes, the NJ HD's (at least around me) only carry the Low Fume.
    May 2014
    Franklin, NC
    9,216
    Have you tried Lowes or independent ACE hardware stores? Heck, even many paint stores around me carry the good muratic acid.
    Support the site
