Thread: Is PoolMath & Recommended Levels Different
    May 2015
    Land O Lakes, FL
    527
    Am I missing something or is there a mistake one one of these?
    In pool Math for a SWG pool, it recommends a target of 9 with a CYA of 60.
    On the Pool School - Chlorine / CYA Chart it recommends a target of 4 with CYA of 60.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2014
    15,130
    Re: Is PoolMath & Recommended Levels Different
    I think you may be using a different calculator. Make sure you're using the one from my signature below or from the TFP Home Page (tab).
    Then, ensure at the bottom you select the 3 criteria (Troublefreepools, your type pool, and how you chlorinate).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    It does the same for me on SWG recommendations.
    The target will vary depending on situation. The critical part is to always stay above minimum. As long as you have enough FC to stay above minimum until your next test and dose, your target is good.
    And really, why worry about target on a SWG pool? If you're plugging FC into poolmath to get a dose, you've sort of reverted to a bleach pool which will have higher values.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by Texas Splash View Post
    Yes, it is a spreadsheet that someone created on this site and everything is set at the bottom. The numbers match PoolMath.
    I understand that there are variables but I also know that then there are discrepancies or something does not match people might get confused. I am fine but it might be something that should be reviewed as it appears that at other scenarios, the 2 sources don't match up for FC in regard to the recommended range/Goal.
    Matt
    38,290
    The PoolMath target is for non-SWG pools. Only a different minimum is provided for a SWG pool. Either way, the target is pretty meaningless. The key is to always stay above the minimum.
    Apr 2016
    Lawrenceville, NJ
    75
    Slight discrepancy for my non-SWG pool with a CYA of 70 for the target. FC target of 8 on the chart and 10 on PoolMath. Both have a lower/minimum FC of 5.
    40x20 IG vinyl (~30k gallons) * Pentair FNS Plus DE filter * Pentair WhisperFlo 2 HP pump * RayPak RP2100 natural gas heater * TF-100 test kit
