Thread: Backwash using a cartridge filter
    Jun 2014
    Newporr,ca
    42
    There is no multi-port on the cartridge filter.
    Is there a way to backwash?
    1500 gallons SPA. 104
    IG, Plaster, 6years old.
    Sand filter Triton ll TR140.
    Taylor K-2006 Complete Pool
    Pentair brominator feeder using bromine. Bi-carbonate. Calcium chloride.
    Jun 2014
    15,159
    Re: Backwash using a cartridge filter
    No. Cartridge filters are not backwashed.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Just to follow up. You remove the cartridges and clean them: Pool School - Maintenance and Cleaning of Pool Filters
    Mark
    Jun 2014
    Newporr,ca
    42
    Crazy... how am I supposed to clean the pool water or waste them etc...
    triptyx's Avatar
    Apr 2016
    1,438
    You'll have to have someone plumb a wastewater pipe into your system if you want to be able to vacuum to waste or otherwise remove water without a separate pump. My setup has a pipe with a hose spigot on it. Not ideal, but better than nothing.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Quote Originally Posted by triptyx View Post
    Mine does as well. The one time I needed to remove some water from the pool I just hooked up a regular garden hose to the hose bibb.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
