Results 1 to 10 of 10
Thread: Flexible PVC
    Flexible PVC
    Hello -
    I'm trying to install flexible PVC this year instead of the normal plastic hoses from skimmer to pump to filter to return. My pool installer used PVC glue to glue the threaded hose fittings into the unions of the pump and filter.
    I tried to tighten the flex PVC onto the hose fitting but the hose clamp wont get tight enough. Can I glue the flex pvc directly to the hose fitting? I'm not aware of anyway to "unglue" the pvc. Should the local pool store stock replacement unions? This way I can use the barbed hose fittings with the hose clamps.
    Thoughts?
    Rich
    Re: Flexible PVC
    Most flexible PVC is designed to be glued to slip fittings. You should be able to find threaded connectors that will thread onto your existing threaded fittings and then have slip fittings that you can glue the flexible PVC to.
    If that isn't enough of an explanation, try posting a picture. That will make it much simpler to explain things.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Flexible PVC
    Where do I find Flex PVC? I have not seen any at the local Lowes, Home Depot, etc. Only the rigid sched 40 and sched 80 is available there.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Flexible PVC
    I saw it in a inground PB/store. Tiger pipe is what they called it.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Flexible PVC
    Quote Originally Posted by NWMNMom
    I'm fairly sure Home Depot carries it or did last year. You can order it at flexpvc.com too.
    Mar 2009
    Houston, Texas
    16
    Re: Flexible PVC
    Here in Houston, I was able to locate it at Lowes. Home Depot does not carry it here. I also went to a parts supplies store that sells part for semi-trucks and purchased heavy duty clamps that are tighten with a wratchet wrench. These clamps work so much better and you can get them pretty tight with these heavy duty clamps. I tried the regular clamps before and they failed me.
    See if that may be of help to you.
    12,500 gal. AG pool.
    Hayward Sand Filter
    PowerFlo Matrix 1.5 pump
    Re: Flexible PVC
    Hello -
    I was able to solve the original problem. I used 1 1/2 to 1 1/4 Fernco Coupling. I don't know how long it will last but it seems to hold better than the other hoses that came with the pool.
    I'll try to post pics.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Flexible PVC
    nwmnmom - plumbingsupply.com has it for 1.40 per ft...8% shipping charge and 3.95 handling fee...could not find it here at lowes or home depot...interesting enough, my HD does not even stock Muratic Acid...manager told me they are prohibited from carrying ma due some "incident"
    Oh well...local HW store carries plenty for me
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Flexible PVC
    thanks all. I'll be on the lookout
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Flexible PVC
    So is "Spa Flex Hose II" a flex PVC? It sure looks and feels like what everybody else calls flex pvc.
    If so, NWMNMom, both HD and Menards in the Twin Cities carry it. At HD, it normaly is on an upper shelp on a large (3-4') reel. Menards only carries short lengths (5 to 25') and is in with the rest of their "tubing" as they call it.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
