Thread: 2 speed pump noise?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    2 speed pump noise?
    Well it is 2:10 am, and I am laying here and can't sleep, so of course I am thinking about the pool. I was just wondering if it is common for 2 speed pumps to make the droning whiirrrwhiiirrrwhiirrrr sound like mine does when set to low (the sound repeats 1 or 2 times per second, not loud, just rarrr rarrr rarrr sort of noise) or if it is just some off harmonic of my plumbing setup?
    Ike
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: 2 speed pump noise?
    It's 3:11, and I'm trying to drag through the last 3 hours of work. My 2 speed pump doesn't hardly make a sound on low. You can hear a little hum from the motor, and the slightly louder churning of the water while standing right next to it. Can't hear it at all from about 10-15ft away.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
