Thread: Incorrect birthday
    Apr 2009
    Central Minnesota
    74
    Incorrect birthday
    I noticed that my birthdate in my profile is incorrect. I can't find any place to change it. It appears that the forum flipped the month and day around is is it was a European date format. Birthday should be June 12th, but forum profile shows December 6th.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Incorrect birthday
    Click this and you should be able to fix it
    38,251
    It can only be changed by admin. Lee is on it and likely already fixed it.
