Thread: Strange jet threading
    Kdfoust's Avatar
    Feb 2016
    Riverside, CA
    10
    Hi all:
    I've a jet in my pool that is on it's own pump line; that is I can valve the pump to run only through that jet. It's in the main pool and has an odd thread size. It's neither 1/2 or 3/4 NPT, it's between them. I'm planning to use it for aeration with a little simple piping hooked up to make a fountain.
    What are these odd threads? What do you think the jet was originally for? The pool was built in 1968 and is a lazy L if that helps to guess the original purpose.
    Thanks!
    Kevin
    27000 gallon lazy L, with attached spa, DE filter, Heater, variable speed pump. I do it all, no pool fools on my property!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Strange jet threading
    My first guess would be for some type of pressure side cleaner
