Thread: Thank you TFP. First SLAM going smoothly.
    Feb 2016
    Gilbert, AZ
    10
    It happened. We went on vacation for a week so I put a floater with a puck in it... came home to find an algae bloom... bummer. (Maybe I closed it too much or the puck is old and less Chlorine or something) Regardless, I started the SLAM according to the directions. Crystal clear water again less than two days later and the chlorine use has really dropped off so hoping for a positive overnight test tonight to hopefully go back to normal. Next time I better just teach a friend to measure and pour each day for me.
    Anyway... so glad I found this resource. The pool is so much better than what I started with last year when we bought the house and me a newbie to pool ownership. We love our pool! And TFP makes it easy!
    ~11,200 gallon in-ground, built ??, pebble tec, hayward 1hp single speed pump on timer, hayward 3025 cartridge filter, TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Thank you TFP. First SLAM going smoothly.
    Nice work! Also bump your FC up to shock level next vaca.
    Please consider supporting TFP, there are lots of nifty fringe benefits!
    More here, CLICK HERE to Become a TroubleFreePool.com Supporter!!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,285
    Good to hear that you were able to hit it right away and get back on track quickly. So much easier when you understand it and have effective methods to use.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,656
    That is awesome to hear! Just so you know the pucks do not go bad like liquid chlorine does but they do add less FC and take some time to do it.
    Kim
