Results 1 to 9 of 9
Thread: Chlorinating Liquid vs. Clorox Bleach with BBB
    Jun 2016
    Washington, D.C.
    3
    Hi all,First time pool owner here; I have been soaking up as much information as I can over the past week. I have decided to go the BBB route instead of buying chemicals and adding them to my pool.I wanted to make sure I gave my pool a good shock and was comparing prices for bleach when I found a Pool Essentials Chlorinating Liquid at Walmart which is cheaper @ 2.50 vs their house brand bleach @ 2.97. Is it fine to use the chlorinating liquid or should I stick with bleach?Thanks!
    38,370
    Re: Chlorinating Liquid vs. Clorox Bleach with BBB
    Welcome to TFP!
    Liquid chlorine and bleach are the same chemical, just different strengths. Use whatever is the best deal. Put the correct setting in PoolMath.
    Also realize there should never be a need to randomly "shock" the pool
    What are your test results and what kit are you using?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I think Jason's auto correct is striking, bleach and liquid chlorine are both the same chemical, just different dilutions in water. Just be aware the stronger it is the shorter its shelf life, so check those coded pack dates. Usually some variation on year and day of year, plus maybe packing location code letter / letters, sometimes have the state abbreviation. So something like 2016-098-TX2 for the 98th day of 2016 packed in Texas facility #2
    Time Vampire's Avatar
    May 2016
    Clay, NY
    23
    I was going to go with bleach because it is usually cheaper than liquid chlorine. Then I found the exact liquid you are talking about at Walmart as well. I have been using that to slam my pool and it is working just fine.
    24ft x 5ft above ground pool (16,900 gallons), Hayward Sand filter, located just outside of Syracuse, NY, in direct sunlight from sun-up until about 6pm. Controlling algae is a "Time Vampire"
    Jun 2016
    Washington, D.C.
    3
    Welcome to TFP!
    I ordered the Taylor 100 kit after reading here. It is on its way. In the meantime the previous owner left me a test kit that allows me to test for Chlorine, pH, and Alkalinity.
    Pool size: 400 sqft; 14000 gallons.
    Chlorine: 5
    pH : 7.4
    Alkalinity: 70
    CYA: 16 (based on pool store reading)
    Total Hardness (Calcium??): 58 (based on pool store reading)
    Based on the above readings (mine + pool store), what is ideal brand for raising CYA and Hardness? Alkalinity, I am going to be adding baking soda per recommended dosage from calculator.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    It would be best to just wait on the kit. Add a half bottle of bleach each day with the pump running and run some numbers when it arrives
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Washington, D.C.
    3
    Quote Originally Posted by Mr Bruce View Post
    Okay, so no need to worry about the CYA and Hardness in the mean time? Secondly, my own testing and pool store testing, of the alkalinity pretty much yielded same results.
    Aug 2009
    SW Wisconsin
    518
    nope..wait until you get your own test kit, to be sure to get accurate results..your CYA is low (according the the pool store reading), but you can deal with that once you test for yourself. If true, you'll want to get your CYA up some more.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Mar 2016
    Phoenix, AZ
    48
    I'd also make sure the bleach you use has the percentage of sodium hypochlorite listed on the label.
    I bought a gallon of Kroger brand bleach thinking I was getting a smoking deal. I then called the 800 number on the label just to be sure it was around 8.3%. It was 2.75%.
    10,000 gallon, inground, pebblesheen, sand filter, TF-100 testing kit, Pentair Rebel
