Results 1 to 12 of 12
Thread: Before and after pictures of our new pool
    Mar 2016
    Chino Hills, CA
    190
    Thought I would share a few photos of our new pool. Water is just now starting to warm up.
    The stain on the concrete to the left of the hot tub is from the salt water when getting out. I think we should have rinsed it down after each use. We are now doing this but the colored concrete is discolored at that area. Hopefully it will wash out over time.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    Mar 2016
    Chino Hills, CA
    190
    Re: Before and after pictures of our new pool
    A few more pictures.
    I hope the dark spots eventually go away in the concrete. The PB sad it could take up to a year to look like the rest of the concrete.
    May 2016
    Gilbert/AZ
    16
    Nice pool, but for the amount of $ you put into it why didn't you get the in floor cleaning system?
    Also did your builder mention sealing the decking to prevent the saltwater stain? My builder advised me to seal mine prior to the salt conversion which will protect the surface and extend the life.
    20K gallon IG Ultra Poz plaster, AutoPilot SWG.
    DE Quad filter, Pentair pump.
    Mar 2016
    Chino Hills, CA
    190
    We have a friend with in ground cleaners at the bottom of their pool and he said it was a waste of money and wish he never got them. Not to mention looking at all of them at the bottom of their pool is not as clean as a pool with out. So far since the pool opened I hardly get anything in the pool. The leaves tend to go to the front of our house and stay there, at least since we moved in last July.
    As far as sealing my PB said not to seal the concrete. He mentioned that sealing is only required on stamped concrete and that it becomes a slip hazard when wet.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Nice pool!
    Mar 2016
    Chino Hills, CA
    190
    Quote Originally Posted by pooldv View Post
    Nice pool!
    Thank you.
    Casey's Avatar
    SW PA
    10,428
    Very nice!
    Mar 2016
    Chino Hills, CA
    190
    Thank you!
    Quote Originally Posted by Casey View Post
    Very nice!
    BNilsen2693's Avatar
    Jun 2016
    Tulare, CA
    28
    Nice! I especially like the water fall/sheer that comes out of the hot tub.
    BNilsen2693 -- 30K Gallon In-ground , Pebble Tec, 55' at the longest, 24' at the widest, 8' at the deepest, Pentair FNSP60 DE Filter, Polaris Sweeper running off a booster pump. TF-100 Test Kit.
    Mar 2016
    Chino Hills, CA
    190
    Quote Originally Posted by BNilsen2693 View Post
    Thanks, we wanted to be able to jump into the deep end so we raised the hot tub and did a spillway.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    I love all that deck space!!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2016
    Chino Hills, CA
    190
    Thanks!
    Here is our latest for entertaining this summer in the evenings. The picture quality in person is amazing.
    https://www.youtube.com/watch?v=Grfz_jDXf_g
