Results 1 to 9 of 9
Thread: leveling ground
    May 2016
    Missouri
    13
    leveling ground
    From my highest point to my lowest point is 41 inches I have read not to add dirt will this be a problem and void any warranty for a above ground pool we are using a transit to measure
    Kc mo, mom of 3 and a farmers wife
    Looking at a 18x40x52 Above ground pool
    Jun 2014
    14,970
    Re: leveling ground
    It is always best to dig down and cut-away the dirt from the high end which will remain more stable as opposed to trying to "build-up" a low area which then would not as stable. So you have a 41" difference due to the angle of the slope you are placing the pool on? That's quite a drop.
    May 2016
    Missouri
    13
    Re: leveling ground
    Quote Originally Posted by Texas Splash View Post
    I know it does not look like it should be 41 inches we have checked several times with a transit. Do you think this will be a problem
    Apr 2013
    Sacramento, CA
    2,769
    Re: leveling ground
    No matter how you do it that is a significant volume of dirt. Is there a slope can we get a picture
    With that volume you don't want fill unless done by a Profesional
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: leveling ground
    It's probably not a big deal, but it will depend on what you have on the high side. You can dig the area larger than the pool and use a retaining wall of stacking blocks to hold the dirt back, or you can just taper the dirt on the high side to make it stable.
    I assume you have equipment available to move a little dirt.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: leveling ground
    You will definitely need to figure out a way to move water around the pool.
    May 2016
    Missouri
    13
    Re: leveling ground
    We are going to lay tile around bottom of pool and yes a slope I will take pic soon
    May 2016
    Missouri
    13
    Re: leveling ground
    tmpPhoto.jpg doesn't look like a big slope but it drops off closer to the corner the lilac bush has to be cut back can't move up any because of water line and other utility Lines in yard
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    331
    Re: leveling ground
    I would dig out from solid ground at the low point. My pool is dug in 18-20 inches in 16 feet across the short side.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
