Thread: Help needed asap
    May 2016
    houston, TX
    10
    Help needed asap
    I live in Houston and we are being hit with another round of rain storms and flooding. My pool is to the brink of overflowing. I have tried using a water hose to drain the pool ( I only accomplished getting a massive headache from sucking on the other end) without success. I tried draining the pool from the drain plug but could not find the attachment. If I remove the hose from the pump filter to drain about 3-4 inches will it cause a problem (the filter is off)? We are in for another 3 days of rain.
    Never Liked Chemistry
    Intex 22 x 52 Round Pool
    SWG and Standard Filter
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Help needed asap
    Welcome to TFP
    Try this, this will also work with just a short hose
    May 2016
    houston, TX
    10
    Thank you.
    May 2016
    houston, TX
    10
    It is working!!!!!!
    Aug 2014
    Northern IL
    4,615
    Yay!
