Thread: Hot tub issues
    Jun 2016
    Cary, nc
    1
    Hot tub issues
    Hello all. I am new to the forum and I am having trouble with my hot tub. It is a Balboa. I recently moved the hot tub to a new location and now I am receiving the following error messages. SLP and LF. The water is circulating, but not heating. I followed the trouble shooting directions on another site, but it didn't work. Any thoughts on a quick fix? Thanks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hot tub issues
    Welcome to TFP
    What year is it or model number... Balboa Water Group - Topside Spa Panel Manuals
    I hope this helps
    Sep 2015
    Brownstown/Michigan
    21
    Re: Hot tub issues
    Hey Mhokenberg. I have a Jacuzzi Echo/Essence hot tub and I ran into a similar issue you did last fall. My control panel is a Balboa model and I had to have some parts replaced on my heater. The repair person unplugged all connections to the heater, including my control panel. When he plugged everything back in the water started circulating and we figured everything was good. It wasn't until later I came outside and noticed my water hadn't heated up at all and I was getting the same error messages your were. I was totally confused and didn't understand. After looking at my heater where the control panel plugs in with the phone jack looking connection, I noticed I had two slots I could plug it into. On a complete blind chance, I unplugged from the jack it was currently in and plugged into the other one. Bingo! The water started circulating like usual and my heater came on and I could finally get a temperature reading again. I figure the repair guy plugged me back into the wrong jack. Not saying this will correct your issue, but it's something to at least try if possible.
    16 X 24 Kayak Above Ground Pool; Vinyl Lined; 12,000 gal; Hayward 1 hp pump; Pentair Sand Dollar Sand Filter
