Results 1 to 9 of 9
Thread: Increase in FC without adding chlorine
    May 2015
    Central PA
    38
    I recently opened my pool and did not have to add any liquid bleach as the levels were still near slam level. I tested FC yesterday and it was 8, however, after testing it today it is at 15? My CYA is 30-40 and there is no CC. PH is 7.4 and TA is 80. What would cause this increase?
    ABG 24' Filter Cartridge 13,600 Gallons
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Increase in FC without adding chlorine
    What test kit are you using? Do you have a SWG???
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,431
    Testing error or someone put chlorine in the pool. No other possibilities.
    May 2015
    Central PA
    38
    Test kit is k-2006. Not sure what you mean by SWG but I think you are referring to the filter.....it is not a sand filter but a cartridge filter.
    I tested it twice today and results both times were 15.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    SWG=Salt Water Chlorine Generator
    May 2015
    Central PA
    38
    Not SWG on our pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Is there an inline Chlorine feeder with pucks in it? Or did someone get helpful and drop a few in the skimmer?
    Chlorine's coming from somewhere. Or you're testing wrong. Any chance you're using the wrong factor to multiply drops?
    10 ml sample, 1 drop is .5
    25 ml sample, 1 drop is .2
    May 2015
    Central PA
    38
    you know what......maybe I used the 25ml mark.........multiplying 30 by .2 gives me FC of 6, which is more in line with my tests over the last few days. How many scoops of the white powder (0871 I think) should I add to my pool water to test for FC. I have been adding 2 scoops.
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by pool$123 View Post
    Usually one is enough. After swirling it to dissolve it, you should see a couple undissolved crystals. If you do, it's enough. Somehow they dissolve when you add drops.
