Thread: Any longer-lived alternative to an R40 pool bulb ?
    My pool has a single pool light with an R40 400W incandescent bulb. The light is adequate, but I've changed the bulb/seal twice over the years, and it only seems to last a short time (given the relatively infrequent use it gets). Last season I put a new bulb in and it was dead by the end of the season ! I've not pulled the unit to see if it leaked, but I suspect the bulbs are just ****. Is there a longer-lived solution out there ? I'm not ready to drop hundreds of $$$ on an LED system, but are there any better options than just rolling the dice on another R40 incandescent ?
    Pool size = 13,000 gallons. Sand filter. In Ground. PebbleTec.
    Mar 2009
    Auckland - New Zealand
    Re: Any longer-lived alternative to an R40 pool bulb ?
    there is unfortunatly not a lot of option for that sized bulb.
    Leak would be one quick killer, and moisture in the cable from a previous water entry is another sure fire way to blow a bulb prematurely, and much harder to check for
    LEDs are the only option for a longer life - however like you said , it has to be balanced against cost
