Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: First time pool owner
    May 2016
    Township of Washington, NJ
    14
    Hello all, just bought a new house with a pool and I need some advice . The local pool store keeps giving me the runaround and I'm sick of it. Just got my Taylor K-2006 kit in the mail. Here are my numbers.
    FC- 3.0
    CC- 1.2
    PH- 7.2
    TA- 130
    CH- 130
    CYA- 100
    I'm new to all this and would appreciate any recommendations. I'm still learning about all the chemicals and I'm constantly looking over the Pool School but I'm still lost. Thanks in advance!
    23,000g | IG | vinyl | Pentair FNS Plus 48 Square Foot Fiberglass DE Filter | hayward 3/4 HP pump | Raypak Digital 199,500 BTU Heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: First time pool owner
    Welcome. I assume your Hayward Chlorinator is a puck dispenser? Your CYA is at least twice as high as it should be. Only way to lower it is to replace water. Thank the pucks for that. Your FC is Faaaar too low for your CYA level. See the chlorine/cya chart in Pool School. You'll need to follow our SLAM procedure in Pool School. We'll worry about TA later.
    May 2016
    14
    So the pucks are causing the high CYA reading? At first I wasn't getting any chlorine reading at all so I added a floater as well. I guess that was the wrong decision, huh?
    May 2015
    Land O Lakes, FL
    527
    The CYA test maxes out at 100 and it might be even higher. See step 9 on this page: Pool School - CYA
    The pucks add CYA and eventually it gets too high and the only way to reduce is with drain and replace water.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    May 2016
    14
    I did the test over again and it looks more like CYA is 85. That's still too high correct? Should I drain a couple of inches instead of half the pool? Should I remove the floater as well? Shut the chlorinator off? Sorry for all the questions.
    May 2015
    Land O Lakes, FL
    527
    At 80 to 90, you need to be 6 to 10. See this page: Pool School - Chlorine / CYA Chart
    If you were to drain 1/2 of your water, your CYA would be 40-50.
    Matt
    May 2016
    14
    So I have no choice but to drain half my water and then refill? And then SLAM it? Sorry just trying to get the steps down.
    Apr 2010
    East Texas
    9,659
    Correct Kevin.
    Mar 2016
    Bakersfield, Ca
    20
    Yup, that's right. Drain half the water and then refill. Been there, done that, got the T-shirt.
    My CYA was~300 from years of 'professional' maintenance by my lawn service.
    You can use the drain water to water lawn or landscaping.
    Since you have CC > 0.5, you have too much organic stuff floating around, and you need to SLAM (after you drain and refill.)
    TC and FC should be almost identical, and CC <0.5.
    The CYA 'stabilizes' the FC by binding some of it, so the effective level is lower.
    Since you probably get ++ rain, your CYA would go down eventually, and you COULD just maintain FC at 12 until then.
    http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
    There's a LONG TECHNICAL discussion of high CYA levels at
    Pool Water Chemistry - Page 3
    but the bottom line is, "it gets harder to manage at levels over ~50."
    See the graph about 1 page down at
    http://www.troublefreepool.com/threads/558-Pool-Water-Chemistry
    Unless your water is very expensive, drain and refill is the easiest. A solar cover should warm it up pretty fast in Fl.
    12,000 gal concrete IG, Sta-Rite MaxEGlas 3/4 HP pump (230v 8A) Sta Rite System 3 Filter, Hayward Ultra crawler.
    10% Bleach bottles on bottom of pool. AquaChek 7 Strips, Clorox SmartStrips, Bakersfield City water.
    May 2016
    14
    Ok thank you everyone for your advice. I started draining the pool about an hour ago. After I refill what numbers should I be most concerned with before I SLAM?
    May 2016
    14
    One more question. I get alot of leaves in the pool. I clean them out as soon as I can but they seem to fall constantly. Will this keep me from having "good", consistent levels? Thanks again.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    No, we have lots of trees that drop lots of stuff in our pool. We run the pump more when the trees are busy to keep debris in the skimmers and off the bottom.
    Feb 2016
    Gilbert, AZ
    10
    If you are doing a partial drain be very sure to test what your CYA really is because it maxes out at 100. I drained 3/4 of my pool only to fill it up and have a CYA reading of 100 again.
    Quote Originally Posted by mgmoore7 View Post
    ~11,200 gallon in-ground, built ??, pebble tec, hayward 1hp single speed pump on timer, hayward 3025 cartridge filter, TF-100 test kit
    May 2016
    14
    Hey all, Im refilling my pool as we speak. Should be good to go tomorrow to test my CYA level. If it is in a good range I plan on starting the SLAM. But it's supposed to rain here pretty heavy tomorrow. Should I start the process or wait until the rain is over with? Thanks in advance.
    DFW, TX
    24,516
    Start SLAMing, the rain won't hurt.
    May 2016
    14
    Ok I refilled my pool and let the filter run for a couple hours. I tested CYA and it is now 60. Drain more water or should I SLAM now?
    DFW, TX
    24,516
    CYA is manageable at 60, just maintain the the correct FC level at target when your SLAM is complete. Chlorine CYA Chart
    May 2016
    14
    Ok great thanks. I really appreciate your advice!
    May 2016
    14
    Just finished SLAMming. Lost 1ppm of FC overnight, have .5 or a little lower CC and water is clear. Just tested as follows. Im letting the FC drop to proper levels from the SLAM.
    FC- 18.5
    CC- .5
    PH- 7.6
    TA- 120
    CH- 110
    CYA- 55
    What should I take care of next? Thanks!
  20. Back To Top    #20
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Well if your losing chlorine overnight the slam isn't over til the 3 criteria are met.
    no over night loss of FC
    water is clear
    no CC above .5
    Also have you brushed the pool? you need to do this daily 1-2 times.
    This scrubs the algae off the walls (you may or may not see green) but
    if it goes cloudy white thats dead algae.
    Run the pump 24/7 til the slam is done.
    Dolphin E10 Cleaning Robot.
