Results 1 to 20 of 20
Thread: Free deck planing or service website?
    Jun 2015
    East Meadow/NY
    82
    Hi there TFP,
    Does anyone have any suggestions for a free deck planning website or service that I can use to draw up a pool deck for a permit application. Decks.com is great but I can manipulate the plans for a pool step cut in.
    Thanks in advance
    14x22 radiant freeform, 6800 gallons, Semi AG, DE Hayward, Hayward SP1580X15 Power-Flo LX Series 1-1/2-HP, installing 7/14/2016, TF100
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Re: Free deck planing or service website?
    Send me a PM with what you are looking for. I may be able to help.
    If you are wanting to do it yourself, have you looked into Google SketchUp?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2015
    East Meadow/NY
    82
    Thank you so much. I'll pm you.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    I just saw your other post HERE. Is the city requiring engineering or are you planning to meet prescriptive building codes for spans and lumber sizes?
    Something like this?
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    They didn't require engineering. They are allowing me to draw it up myself. I'm trying to figure out if i can just go with nailing the 2x6 rim joist to the 4x4 post. I'm only going 28" above grade.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Quote Originally Posted by mapromonyc View Post
    I doubt they will allow the deck built in that fashion. That would place all of the deck's weight in a shear load on only the nails.
    A 4x(H) beam should sit on top of a 4x4 post with a Simpson EPC or PC style post cap (or equivalent). The joists should span from beam to beam with joist blocking in between and an A35 (or equivalent) from the blocking to beam. I'll get you a detail tomorrow if needed.
    The picture posted above was built in exactly that manner and was planned and inspected.
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    Thank you. Do you think I'll need a concrete form column 36" or can I dig 36" and pour concrete and place post on top and back fill?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    36" because of the frost depth?
    Either way, the footing should be 8" above the grade and use a PB or CB style anchor for the post.
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    I'm not really sure of the frost depth. I was told that that would be sufficient. I created a deck plan through lowes. Would this be better?
    Jun 2015
    East Meadow/NY
    82
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    Thank you.
    Jun 2015
    East Meadow/NY
    82
    This is helpful
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    I'm not sure why you want to go the footing route though. You can likely float the deck on piers since the pool itself is doing the same thing.
    Make sure that the lumber spans are within their rated capacities and positive connections are made between members.
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    The building department mentioned I can dig 36" then add cement but put some type of bracket down in the hole then attach post. Did I understand that correctly? Thought the brackets are attached on the footing above grade
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    The bracket would be an PB or CBSQ type anchor...
    -Brian-
    POOL BUILD
    Jun 2015
    East Meadow/NY
    82
    That would be the bracket above grade? I may have misheard him.
    Jun 2015
    East Meadow/NY
    82
    Any bracket would require me to bolt into the post.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    The footing will sit 8" above the grade and protrude 36" deep. The anchors have a lower portion that gets embedded into the concrete, allows for a 1" standoff height, and has upper supports that provide a positive connection for the post.
    The anchor details pictured above show that type of installation.
    I don't think you are clear on what the building department is asking of you. It certainly sounds like they are looking for construction documents that show a foundation and framing plan as well as connection details. They may not want engineered but the lumber specs will need to meet the span ratings for live/dead loads, shear and uplift forces....
    -Brian-
    POOL BUILD
  20. Back To Top    #20
    Jun 2015
    East Meadow/NY
    82
    Understood. They said they are just following the 2010 NYS building codes. It gets confusing because I see excerpts on freestanding vs ledger board attachment.
