Thread: Inspect cell light is on and low salt
    Jun 2015
    Ottawa/Ontario
    340
    Is this just a "need to clean" light? Or is it coincident that my salt is "low" - present reading on T15 readout says 2700 ppm....
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Oct 2015
    Katy/Texas
    411
    Re: Inspect cell light is on and low salt
    You have to satisfy the cells salt ppm requirements. Have you tested the water.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jun 2015
    Ottawa/Ontario
    340
    3 ways: with a strip, which says low salt; the T15 readout and PB both measured salt around 2700 ppm
    Jun 2015
    Ottawa/Ontario
    340
    Not sure why the strip is showing low....i actually don't know what the most reliable measurement is....
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If the cell is in need of cleaning it can cause the salt level to read lower than it actually is. But if you have testing that also shows low salt, then you may need to add salt. Clean the cell then check the instant salt reading.
    chiefwej
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    2700 is borderline of what the SWG can operate at. Keep in mind also, that the SWGs salt sensor as well as any sort of salt test kit have inaccuries of a couple hundred either way. It may actually be a little lower or a little higher.
    Almost all SWG manufacturers 3200 to 3400 ppm as ideal, but can operate a little higher or lower.
    If I were you, I would add enough salt to get it from 27 to 32 and see if the low salt alarm goes away.
    Divin Dave,
