Thread: Calcium Hypochlorite and CYA
    Jul 2008
    Seacoast, NH
    250
    Will Calcium Hypochlorite raise my CYA as well as hardness?
    Thanks.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Feb 2008
    Denton, TX
    5,061
    Re: Calcium Hypochlorite and CYA
    No, calcium hypochlorite does not contain CYA. It will raise you CH fairly quickly though.
    Jul 2008
    Seacoast, NH
    250
    Thanks.
    1.5 HP Pump
    Mar 2007
    San Rafael, CA USA
    12,082
    The basic chemical rules that are independent of concentration of product and of pool size are as follows:
    For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm.
    For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
    For every 10 ppm FC added by Cal-Hypo, it also increases Calcium Hardness (CH) by 7 ppm.
