Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Scaly Crusty Gross Stuff on Vinyl Walls of Pool
    May 2016
    Springville/Alabama
    21
    Hi! I have just got my cloudy pool "clearer" enough that I can nearly see the bottom. This is a HUGE improvement from the swamp that it was. Now I see there is gunk on the walls of the pool, crusty, hard. What do I do (besides scrubbing) - which I have done, but wondering if there is a product I should try. Thanks
    Jana D
    Pool owner for six years. Above ground. 15 x 30 oval. Vinyl liner. About 12,000 gallons (per online estimation I found). Hayward pump/sand filter. Learning about the BBB method. Can't stand algae! New to test kits and learning those too!
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    434
    Re: Scaly Crusty Gross Stuff on Vinyl Walls of Pool
    Quote Originally Posted by Jana D View Post
    ... Now I see there is gunk on the walls of the pool, crusty, hard. What do I do (besides scrubbing) - which I have done, but wondering if there is a product I should try. Thanks
    I had what sounds similar, it was off white in color, thin layer. very hard if not impossible to remove. What color is yours? I dont have any idea for product though, wish i did. Good luck.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    30,426
    It sounds like calcium scale but you can't guess at it and hope it goes away....you have to identify it. Can you post a set of current test results?
    May 2016
    Springville/Alabama
    21
    My readings from my analysis at the pool store on May 23:
    temp 80
    CYA 90
    Tot chlorine 6.5 (had just shocked)
    free chlor 6.5
    pH 7.5
    total alk 108
    total hardness 102
    I'm new to test kits and I do have one but it is older (so I don't know how good it still is, though it's been kept in like new shape)
    But when I did a test on my own, the cal hardness was high (if my readings were accurate)
    Jana D
    May 2016
    Springville/Alabama
    21
    And I'm concerned now too because my kids were in the pool ....and that's how we noticed it! My son said the wall feels "gross" and "bumpy". Now I'm worried because I let them swim!
    Jana D
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Calcium Scale is like grow-your-own sandpaper. Severe cases can scrape the skin right off any elbows or knees that bang against it. Instant roadrash.
    I'd trust your old test kit's "high" CH readings over the pool store's.
    If you drive the CSI down to negative numbers by lowering TA and pH, you can possibly dissolve the scale. It will at least soften it a bit so scrubbing will get it off. But to do that, you're going to need a test kit you can trust right there onsite.
    May 2016
    Springville/Alabama
    21
    My concern about lowering my pH though is that it will cause an algae bloom AGAIN! Question? Could my city water be the problem? I only ask because our beautiful spring water was changed over to a river that is...well nasty. Our tub and toilet are orange tinged!
    Jana D
    Richard320's Avatar
    Jan 2010
    19,037
    pH has nothing to do with algae. Chlorine levels control algae.
    Orange tinge means Iron, which is a whole 'nother problem. It could tint the Calcium scale or stan the pool walls or make the water look greenish, but it also doesn't affect algae.
    May 2016
    Springville/Alabama
    21
    Ok got it. So I realize this answer is probably on TFP but what chemical do I use to drive down pH and TA?
    Jana D
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    More on managing scale here, Pool School - Calcium Scaling
    May 2016
    Springville/Alabama
    21
    The only reliable solution for removing calcium scaling is a full drain and acid wash.
    What? I've got to completely drain the pool? Please say it isn't so. I think I'm going to cry
    Jana D
    DFW, TX
    24,502
    I would try other steps first. Draining a vinyl pool often results in liners shifting and shrinking and needing to be replaced.
    DFW, TX
    24,502
    Here is the page for Pool School - Recommended Pool Chemicals
    Go to Poolmath and enter your test results in Now and change PH and TA in Target to see hpw they impact CSI. Keeping it at -0.6 to -0.8 and brushing as often as you can stand to is the first thing to try. It will take a long time, about as long as the scale has been building up. If there are very rough places you can sand them with wet/dry sandpaper to smooth them.
    May 2016
    Springville/Alabama
    21
    Oh thank you! So glad to read this. I was sweating bullets. Well I've got to add (so hopefully anybody reading this it will help) we just got our plastic white steps out....and a bunch of algae and stuff came out - So I believe that has been a big part of the problem, not the calcium scaling really, but nonetheless part of the problem.
    Jana D
    DFW, TX
    24,502
    May 2016
    Springville/Alabama
    21
    Oh I know. Been doing that. But realized we were fighting a losing battle since all the gunk was under the stairs. I'm stumped though about the calcium scaling. Could our hard water be contributing? If so, then draining and refilling probably won't help, will it? Something is obviously not right.
    Btw, just did a test and my pH is 7.6 and CH is 110
    But from what I've read clouding and scaling happens when CH is too high so...
    Jana D
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    If the pH had been high and the TA had been high, it is possible the the CH was higher but fell out of solution and deposited on the surfaces of the pool. You can lower the pH to around 7.2 and lower to TA to the 70-90 range to see if that helps to release the calcium from the walls. Sequestrant for metals and calcium can also help remove calcium scale.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Rogers, AR
    427
    My home was a foreclosure so I knew nothing about my pool's history. My light fixture was covered in scale. I ordered a new light and my pool company never came out to replace it.
    So one day my daughter and I got in and scrubbed the dickens out of it. My pool clouded really bad but a lot of the stuff was coming off. I asked about it on here and Richard told me to keep the TA down (mine was on the lower side anyway). It didn't all come off but over time and following TFP methods the light has shed it's skin and looks like a champ.
    Listen to Richard...he knows his stuff.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    DFW, TX
    24,502
    Just fyi, draining and acid wash is only applicable for plaster pools. It won't work in a vinyl pool.
  20. Back To Top    #20
    May 2016
    Springville/Alabama
    21
    So should I use muriatic acid or sequestrant (whatever that is) for metals and calcium?
    Jana D
