Thread: I thought I was dealing with algae. Not sure substance on bottom of pool.
    Jun 2016
    Detroit/Michigan
    1
    My pool had blk looking substance on the bottom I vacuum it out with cordless vac. Pool was crystal clear. turned filter off for a day nothing on bottom of pool. When I turn filter back on within a hour substance back on bottom of pool. Can this be a cracked finger or what I was being told if it was algae it would have settled when I turned the filter off. Help pleaseee.
    My pool is 28 ft above ground round. Hayward pump/filter
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    430
    Re: I thought I was dealing with algae. Not sure substance on bottom of pool.
    Take a picture of what you vacuumed out?
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    It could be just dirt?
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Aug 2010
    Dallas, TX
    4,052
    Turn off pump for an hour. Hold sock over return while someone turns on the pump. If you get sand, you know where it is coming from.
