Thread: Help -2011 Hayward Super Pump 1 1/2 hp, 5 yrs old, HUMMIMG ONLY, no change
    Jun 2011
    South Shore - Massachusetts
    39
    HI Folks,
    I read the related posts but I cant pinpoint it to my problem.
    I Had the pool closed last September after a trouble free season. I opened my pool for summer today, and discovered that the pump just hums loudly, I cannot seem to turn the impeller by hand, at least I think its the impeller Im reaching, only thing I can reach inside with my fingers once I remove the basket. While motor is humming I strongly wrapped side of pump with metal wrench, no change, but when I wrapped the back of pump, it stopped humming and tripped the circuit breaker. I reset breaker, turned on pump and still humming loudly.
    Is it time for a new pump after only 5 yrs??? Geez I hope not, Or could it be a capacitor or centrifugal switch internally????
    Thanks again for any guidance folks! Much appreciated!
    Ed
    Massachusetts
    "Keyhole" 20 X 40, approx. 24,000 gals., Salt Water, vinyl liner, Goldline T-Cell 15 SWG, Aqua Plus Controls, Hayward 1 1/2 hp Super Pump, Hayward Gas Heater, Hayward 4 Cartridge Filter, Solid Safety Cover with Center mesh panels, AquaBot Remote Control Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Help -2011 Hayward Super Pump 1 1/2 hp, 5 yrs old, HUMMIMG ONLY, no change
    Did you ever have a leak at the bottom of the pump? That could be a sign rusted bearings seizing the motor shaft but you should confirm via the back of the motor if you can turn the shaft or not.
    Replacement motors are usually cheaper than entire pumps plus you can get a two speed motor to save on energy costs.
    Mark
    Jun 2011
    39
    Hey Guys,
    Thank you,
    I removed the rear cover, I found it too crowded in there to get around spring-plate assembly and expose shaft end to try and turn, so I removed the pump itself, removed spring-plate assembly, and exposed shaft (guess I could have done while installed), but with a wrench I finally turned and broke the shaft free to spin now, must have been badly corroded over the winter, shaft will turn with fingers/hand spin, but once i spin it and remove my hand, it stops, it will not continue to spin. Is that the proper "tension", or should I continue to work it to c if it spins on its own more freely after I start it with my hand? Also, replace run capacitor while I have the pump out and its easy to get to?
    Thx
    Ed
    mas985's Avatar
    Pleasanton, CA
    11,741
    Plug it in and see if it starts but even if it does, the bearings are probably shot. It might work for a while though. I wouldn't replace the capacitor since the motor is on borrowed time.
    Mark
    Jun 2011
    39
    will do, appreciate the advice as always!! Will let you know
    Ed
    MA
    Jun 2011
    39
    Running perfectly, apparently corroded up over winter, got axle shaft to turn fgreely now working fine, fingers crossed
    Thanks
    Ed
