Thread: Newbie pool boy/ Cleaning ?
    Jun 2016
    Lake Wylie SC
    1
    Good Afternoon,
    Searched the forums without any luck so going to post my question here. Just purchased a home with an existing pool. It has the old decorative waterline sticker around it. The adhesive feels hard underneath the sticker. It is also flakey in some places. Not sure how to remove this without damaging the fiberglass. Any suggestions are welcomed. Thanks in advance.
    10800 IG Fiberglass Hayward S220T sand filter Hayward 1 HP Pump Circupool SWG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Newbie pool boy/ Cleaning ?
    I would try scraping carefully with a putty knife first. WD-40 can do wonders for removing the sticky residue left by paper stickers so that might be worth a try in a small area. Just try not to get it in the pool water...
    Isolated Spa - 345 Gallons
    Aug 2010
    Dallas, TX
    4,052
    Goo gone is also excellent for removing glue.
