Thread: feaz signing on!
    feaz's Avatar
    May 2016
    Du Quoin, IL
    6
    feaz signing on!
    Hello everyone! This is my first year on troublefreepool.com but I have owned above ground pools since 1999. First one was 18'X33"X52" and the one presently is 12'X24'X52" and both were buried 2' in the ground which has not been an issue with either. I now live in a deeply forested area near a small lake and have experienced more algae problems since installing this second pool which is to be expected. I spent a small fortune last year on algaecide, shock, pH+ and chlorine tablets with little success. I was directed to your site after talking to another pool owner that is familiar with it. I have already gathered much info from the Pool School and other offerings but have some questions and comments I plan to post on separate threads. I sure hope this works out for me and my yearly pool cost are drastically reduced.
    Paradise 12'X24'X52" above ground pool buried in-ground approximately 2', Millennium/Waterway 22" High Rate Sand Filter/1.5HP pump motor/250lbs. #20 grade silica sand
    Vinyl liner treated lumber deck frame and composite top deck Installed 06/2012 Taylor K2006 Test Kit
    Jun 2014
    15,189
    Re: feaz signing on!
    Welcome to TFP! Glad your friend referred you to us. Hopefully we can clear-up some things for you and dispel any myths out there about pool care. Nice to have you with us.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    TFPC will definitely make things better!
    Casey's Avatar
    SW PA
    10,450
    Welcome to TFP
