Results 1 to 7 of 7
Thread: Mineral Springs Box shuts off
    Jun 2016
    lexington, sc
    4
    Question Mineral Springs Box shuts off
    After a liner replacement, water refill and filter sand replacement I also replaced the T Cell 15 for a fresh start with everything.
    When I plug in the Mineral Springs MS-11 control Box the power light comes on, the flow light blinks for 20 seconds then goes out, the generating light comes on then 15 seconds later all indicator lights go out.
    The new T Cell is a generic from PoolSupplyWorld, they indicate that it's compatible.
    Side Note: the display panel remains on, however the mineral reading is very low compared to the reading from my pool store.
    Any suggestions as to what could be going wrong?
    In-ground Salt Pool, 28,000 gal, traditional L shape.
    Mineral Springs MS-11 control Box (2004)
    Hayward Sand Filter and SP714 vari-flow valve
    Generic T Cell 15 by Pool Supply World
    New Vinyl Liner 5/2016
    Jun 2011
    Long Beach, CA
    2,778
    Re: Mineral Springs Box shuts off
    Welcome to TFP!
    Please post all the readings you get when you go through the diagnostics.
    Jun 2016
    lexington, sc
    4
    This is a list of the reading I am getting, however the display shuts off after just 1.5 minutes.
    2600
    87
    12.6 (unstable, keeps changing)
    0.0
    59P
    - 0
    AL - 0
    r 1.10
    Aug 2010
    Dallas, TX
    4,052
    What are those??
    How are you testing, and what do those numbers line up to?
    Jun 2011
    Long Beach, CA
    2,778
    I believe it could very well be the current limiter if your system has one, see this long thread, Aquarite Not generating - lights not on.
    Look on your main board for a black disk about the size of a quarter and it might be burnt or cracked. Make sure the power is off before opening the box to inspect the board.
    Jun 2016
    lexington, sc
    4
    Thanks. I'll check that out and let you know what I find.
    Jun 2016
    lexington, sc
    4
    It was the current limiter (thermistor). Ordered the part (570-1062-ND) from Digi-key. Unsoldered the old part and soldered in the new part. Put the motherboard back into the box and powered it up. Working like new again.
    If someone else has this issue, make sure you have a high temp soldering iron to replace the thermistor. The solder pad on the PC board is large to dissipate heat and therefore a little hard to solder.
    Thanks to everyone that contributed to the successful fix to my problem.
