Thread: Booster Pump Replacement
    Apr 2015
    Granada Hills, Ca
    24
    I have a couple of questions:
    I am replacing an old Sta-Rite Booster pump ( PLBC-178L ) with a new Polaris PB 4-60 Booster Pump.
    Questions are...currently plumbed in with rigid PVC - can I add unions on supply and discharge.?
    Also should I bolt down the new pump ( using concrete anchors ) or is it necessary?
    Thanks
    Sandy
    May 2015
    kingston springs, tn
    102
    Re: Booster Pump Replacement
    Questions are...
    1. currently plumbed in with rigid PVC - can I add unions on supply and discharge.? No reason why not
    2. Also should I bolt down the new pump ( using concrete anchors ) or is it necessary? My booster is located in a very controlled environment where no animals or kids can access it. Mine is not bolted down and I have never had a problem.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Apr 2015
    Granada Hills, Ca
    24
    Thanks pondfishr...
