Results 1 to 9 of 9
Thread: New test #'s for Waterbear
    May 2008
    Hockessin, Delaware
    48
    Ph - 7.6
    CL - 2
    T/A - 80
    CYA - 60
    Calcium - 200
    Salinity - 3320
    Also just added the Borates today. Will try to order test strips and measure when they get here. Do you think i need to raise the Calcium level to 300 for gunite ? Any other suggestions ?
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New test #'s for Waterbear
    Is anyone else allowed to answer?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by frustratedpoolmom
    I was wondering the same thing
    You're done SLAMing when:
    mas985's Avatar
    Pleasanton, CA
    11,741
    Too bad, I had the perfect answer too.
    Mark
    May 2008
    Hockessin, Delaware
    48
    I am sorry i would like all input i was just replying to a previous post where waterbear asked me to get him a new set of test numbers. Everyone please repond.
    pentair DE filter
    Aquapure 1400 SWG
    mas985's Avatar
    Pleasanton, CA
    11,741
    If you have high CH fill water and your CH normally rises quite a bit during the season, I would say leave it alone and let it rise on it's own. However, if the CH is relatively constant over the season, then you may want to add some now.
    Mark
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by GZelano
    Looks like you managed to start a new topic instead of replying, though...
    --paulr
    BBB "Intermediate Swimmer"
    May 2008
    Hockessin, Delaware
    48
    yeah i'm not the sharpest tool in the shed !
    pentair DE filter
    Aquapure 1400 SWG
    Guest
    Not sure which was the original thread since you have the one about test numbers and your pH spiking and the one about the rough suface of your plaster in your spa and I responded to both threads (and I feel the problems are related so all three should probably be combined into one thread) so I will refrain from answering untl you let us know which topic you are referring to.
