Results 1 to 8 of 8
Thread: High Amps, high temperature on 2hp pump system
    ScottBostwick's Avatar
    Jun 2016
    Okeechobee FL
    4
    Hey everybody
    I'm new to this site/community. I am an instrument tech at a power plant and a little embarrassed as to why I can't figure out why my pool pump draws so many amps. Let me start by saying this is a brand new motor/pump assy. I just purchased Hayward Super II HP Pool Pump because I was on my 3rd or 4th motor on my other 2 hp Jandy pump. I got tired of replacing motors on the other pump and just bought the Hayward. I have a 30 amp service to my pool control box fed with #6. It's about 75 ft run. My pool control box has a mechanical timer that allows the pump to run about 6 hrs a day. There is a 20 amp GFCI breaker in the control box that supplies the mechanical timer and motor. all wires are #10 to the timer and to the motor. The motor is six ft away from the box. The DE filter is clean with a 12 psi (new Gauge) reading. With skimmer and bottom drain vales fully open the the suction of the pump, and waterfall and wall return jets valves fully open my amps run 12.5. The FLA of the motor is only 10.8. And with my IR gun the surface temp of the motor displays 160 f. I played around with the valves by closing it off restricting flow, and my amps do go down, but I know I shouldn't have to do that. I may be leaving something out, so any ideas please..
    20,000 gal Gunnite kidney shaped Pool with small waterfall
    Jandy DEV60 Series DE 60 sq. ft. In Ground Pool Filter
    Hayward Super II Maxrate Inground 2HP Pool Pump SP3015X20AZ
    Hayward AQR15 Aqua Rite In-Ground Chlorine Generator
    38,262
    Re: High Amps, high temperature on 2hp pump system
    Welcome to TFP!
    That is a big pump and it is going to use a lot of power. That temp does seem a little higher than it should be.
    Casey's Avatar
    SW PA
    10,427
    Welcome!
    Jun 2016
    Okeechobee FL
    4
    Yeah I agree it's going to pull some power, and I'm ok with that. I just don't like that it seems to be working really hard for no reason.
    Thank you!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Have you verified the input voltage at the pump while running? Which exact pump do you have?
    Jun 2016
    Okeechobee FL
    4
    Yep I have verified the voltage at 240 vac while running. This reading was takin before and after the mechanical timer.
    Hayward Super 2 Maxrate Inground Pump 2 hp, SP3015X20AZ
    Jun 2016
    Okeechobee FL
    4
    Am I able to put a 1 1/5 hp motor on this pump?
    Do you know off hand if I'm able to put a 1 1/5 hp on this pump.
    Jun 2016
    Mechanicsville
    3
    You can put a 1.5 on that pump but would need to change the impeller at the same time.
