Results 1 to 11 of 11
Thread: Adding Borates, Check My Starting Point Please
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    I'd like to give borates a try this year, so I ordered the appropriate weight granules and they're on the way. Having read the pool school article, I'm looking to adjust my numbers before adding the borate. My latest test results are such:
    June 01, 2016 @ 11:27
    Temperature: 74
    pH: 7.6
    Free Chlorine: 2.8
    Combined Chlorine: 0
    Cyanuric Acid: 100
    Total Alkalinity: 80
    Calcium Hardness: 90
    Sodium Chloride: 2200
    I have additional salt dissolving now to bring up to 3400, and I've been vacuuming to waste to do partial water changes to lower the CYA. I will be adding some bleach if today's run of the SWG does not boost the FC. Reading the article on TA, I see I shouldn't necessarily adjust for the sake of a number, yet the borate article indicates it might be better to adjust to the lower end of the range before adding.
    So, what would you do?
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    Aug 2010
    Dallas, TX
    4,052
    Re: Adding Borates, Check My Starting Point Please
    Is your pH fairly stable? Some pools like different TA. Mine swings at 80, so I'm trying to get mine down to see if it is more stable at 70. You want TA to be correct before you add the borates, because once you add them it is really hard to move TA.
    Always boost FC with bleach unless it's only off a little bit, don't overwork your SWG. I only use my SWG to maintain.
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Quote Originally Posted by RobbieH View Post
    Yes, it's been 7.6 since the day after I set it up (25th of May).
    I usually follow that advice. I'm trying to dial in the run time on the pump/SWG.
    Aug 2010
    Dallas, TX
    4,052
    Well, that's only a week, but that said I know in a week because mine will swing from 7.2 to 8.0 in a week. If you are that stable already, I say go for it!
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Robbie? Aren't borates supposed to help control pH bounce? If I am considering adding borates to help control my bounce doesn't it stand to reason that I am going to bounce during the process?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by mikemass View Post
    Yes, but you want to have TA as close to perfect for YOUR pool before adding them. About 4 years ago I added them when I had a Liquidator. This cleared the problem of "white stuff". But when I discovered a LQ is not a good solution for a pool my size, I went SWG. My pH swings down .8 points in a week, and I have to use a gallon of MA to get it back up to 7.8. The borates in the pool did not help as my TA was 90. I finally got it down to 80, and it still had swings. I'm on new plaster (2 years old now) and new water, and still my TA is 80 with the same swing, but no borates. I'm waiting to get down to 70 to see if it's better, because I already know from experience that even with borates my pH will fall with TA at 80. I may even have to go as low as 60. I want the borates to make a good thing better, I don't want to attempt a band-aid fix on a problem again. Buying that much boric acid (well over 100 lbs) is not cheap.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Interesting. I attempted the borates a few seasons ago. Did not notice much of a difference in the pH bounce. But then again I probably didn't have my TA low enough. Considering trying it again as I am sure after 2 full years I am depleted of Borates now.
    Aug 2010
    Dallas, TX
    4,052
    Borates won't go away over time, only through splash-out and water replacement. But, you found the same thing I did. If TA isn't perfect, borates are not going to help much. They do seem to prevent scaling if pH goes off though.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I've derailed this thread enough - Sorry to the OP. But while we are at it. You think my 3+ year old borate test strips will still be accurate? They've been stored in a dark cabinet in my kitchen all this time. I know Borates don't get lost on their own, but this was back in the 2013 season.... That's 3 partial drains for winterizing. Another partial drain for overshooting my salt. And 3 seasons of splash-out. So I am expecting them to be quite low.
    Aug 2010
    Dallas, TX
    4,052
    They probably work. That's about how old mine are, and they register 15 on my water which is about right. I did go back up to 50 at one point, but then I had a massive leak in my light niche and lost a lot of water.
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Looking back at my results from last season I see that 7.6 pH is where I was 90% of the time. My TA, however, fluctuated toward the end upward of 120, from a start of 70. I have no reason to believe that it won't go up without careful attention.
    I'll work on getting it down to 70 while waiting for the boric acid.
