Thread: Heater problems, need recommendation for company on LI to replace
    Jun 2012
    Smithtown, NY (Long Island)
    65
    I got my pool already for pool season, turned on the pump and was greeted with a broken PVC that was connected to the heater's exchange unit, which resulted in a fountain of water shooting out. I don't have a way of bypassing the heater so my only two options are to replace the heater or redo the plumbing to bypass the heater. I'd like to have the heater so I am looking for a company on Long Island that does replacements. I've called two so far and one doesn't do that service and the other is not returning my call. I can't run the pool without fixing this so I have a big green swamp in my back yard. Any recommendations would be greatly appreciated. Thanks in advance
    ~30,000 Gallon Free Form Pool; IG; Vinyl; DE Filter; Installed 2005
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Heater problems, need recommendation for company on LI to replace
    I had to replace my heater last year. Got it on Amazon, which was the absolute cheapest way to go. No one local would touch their price. Then I re-plumbed the PVC to fit to the new heater's input and output. I also bought 2 Jandy Never-Lube Three-way valves and created a bypass for this heater (prior one didn't have it). Highly recommend a bypass. Comes in very handy for the times when you needs to drop the pH level.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    Quote Originally Posted by pisstol27 View Post
    Can you post a picture of the leak as maybe it is something easy to fix.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey,
    Im from Smithtown. In fact just replaced heater
    I have a pool wizard that can either fix or replace for you. He has been servicing my pool for over 20 years. Not the cheapest but absolutely the most fair and honest. Plus it helps that he can do just about anything. If you are interested PM me.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Jun 2012
    65
    Thanks Mitch...Must be something in the water in Smithtown! I had already contacted Deep Blue Pool before I saw this post and wound up going with them. Their prices seemed fair and were very nice and helpful. All my equipment was about 15 years old with a lot of leaks, had to replace the filter, multiport valve and pump in addition to the heater. Fun times!
