Results 1 to 7 of 7
Thread: Pool SLAM Overnight Loss
    Jun 2015
    Voorhees, NJ
    49
    I am in the process of SLAMing my pool. The overnight loss into this morning was 1.5 ppm. This is probably a dumb question, but is that close enough? If it's imperative that it's 1.0 or less, I will continue adding bleach. I just wanted to check first. My pool water looks perfect. There is no discoloration or algae visible.
    Inground Pool - 35,000 gallons - SWG (Nature2 - FUSIONSOFT1400) - Cartridge Filter
    Aug 2010
    Dallas, TX
    4,052
    Re: Pool SLAM Overnight Loss
    Close enough is zero with a tolerance of zero.
    1.5 ppm is a loss.
    Sorry man, keep going. Algae does not have to be visible to be present. It could be hiding somewhere.
    Jun 2011
    Long Beach, CA
    2,787
    Short and to the point, continue on with the SLAM.
    Jun 2015
    Voorhees, NJ
    49
    Thanks! I'll keep SLAMing.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Quote Originally Posted by RobbieH View Post
    I'm stealing this for my sigline.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Jun 2015
    Voorhees, NJ
    49
    I'm glad that I didn't stop SLAMing. I came home today, and my FC dropped from 20 to 10. I am surprised to see such a large drop. Is this normal? The drop yesterday was only 5 ppm. I'm not able to add chlorine throughout the day, as I'm not home.
    Jun 2011
    Long Beach, CA
    2,787
    We need test numbers, if there is very little CYA then you could lose most of the FC during the day.
