Results 1 to 9 of 9
Thread: Raypak 2100 heater electrical issue?
    Jun 2016
    Franklin, MA
    9
    Hi,
    A purple wire had broken off from the on-off switch. We replaced it. The temp. gauge clicks like it's calling for heat, but nothing happens. The pilot IS lit. We don't know what to do now....
    Thanks in advance!
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Raypak 2100 heater electrical issue?
    Welcome to the forum. A few things to start, if you have an ohmeter. Pull the wires off the terminal for the firemans switch. If thats ok, then try the same on the pressure switch.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Even though the pilot is lit, you have a millivot system, you have to have the correct amount of millivolts coming from the pilot generator in order for the system to work. You could also not have enough water pressure coming into the heater or a bad pressure switch. Any number of things. If you have a volt/ohm meter you can start checking many of these things yourself. If you do not, hire a company to check the unit out.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2016
    Franklin, MA
    9
    Quote Originally Posted by banditig View Post
    Where are each of these switches? We have tried looking at the manual online, but it hasn't been helpful.
    Quote Originally Posted by ps0303 View Post
    We have the meter thingy, but no idea what part is which. The manual doesn't help very much...
    16x32 In-Ground installed in 1984 / converted to bromine, replaced liner, filter, heater ~ 15 years ago
    Raypak 2100 pool heater
    Jun 2016
    Franklin, MA
    9
    I think we have figured out that there is not enough millivolts. We are supposed to have around 700, and it is reading around 200. How does this happen and what can be done to fix it?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Over time the part gives out. If the flame is strong then all you need to do is replace the thermocouple. Here is the part # Parts4heating.com: Raypak 600019B THERMOCOUPLE 35 750MV-KIT
    Paul
    Jun 2016
    Franklin, MA
    9
    YOU. ARE. AWESOME.
    Thank you!
    Jun 2016
    Franklin, MA
    9
    Can I install that myself? Or should I hire someone?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It depends on your level of knowledge and confidence. However, when messing with gas its best to not take chances.
    Paul
