Thread: Wall bulge, is it common, should I be worried?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I have a 15k gallon (or so) fiberglass in ground pool. Something I have noticed over the past few years is the bulging inward of two of the sides (across from each other). The pool is about 15 years old (I moved in 2 years ago) I am not sure how long its been like this. Its pretty noticeable and I am curious if this is something that happens and if I should be worried of a catastrophic disaster.
    Thank you!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    Jun 2014
    15,226
    Re: Wall bulge, is it common, should I be worried?
    Certainly warrants concern, but not sure what can be done at this point other than to monitor it for stress cracks or a leak. Interesting that it's pushing inward which would imply a lot of external force. If you know that manufacture of the pool you might want to contact them for some advice as well.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    As I mentioned I am not sure either how long its been doing this, the pool is coming up on 16 years old. I am hoping its been like this for a long time and has settled. I think you responded to another thread on having a crack fixed. The crack is away from the bulging walls, although I can see general stress anywhere causing issues. This really sucks... I am wondering if home owners insurance ever covers pools.
