Results 1 to 11 of 11
Thread: So much rain! How to balance?
    Oct 2015
    THE WOODLANDS, tx
    65
    Hi all,
    Well our first weekend swimming went great! We've been getting a lot of rain here and I've had to drain the pool because it was overflowing. I've lost CYA and calcium (which was already down to 170) is now at 120. We're expecting more rains in the next few days.
    So how should I balance the chemicals? I added $100 worth of calcium last year to take it up to 250, now it's low again. Should i keep adding calcium and watching it go down the drain? Or should I wait until the stormy weather has passed (next couple of weeks) and then add calcium?
    Also I have a bucketful of trichlor tabs that I got when I wasn't planning on using the TFP method. Since my CYA is low anyway, should I just use these for a month or so? *ducks for cover*
    Thanks for any tips!
    ~20,000 gallons, IG white plaster, Cartridge filter (make unknown), Filter Pump (Jandy Stealth Model # SHPM2.0), Probably over 10 years old, Spa, non-functional SWG (bad sensor), Taylor K-2600
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: So much rain! How to balance?
    If you already have the trichlor pucks and are low on CYA, I would use them. Why waste them just because the TFP method is preferred? When CYA gets back to proper level, go back to TFP method.
    As far as Calcium - You have a plaster pool. You need to get that up to proper levels. It sucks that more rain may be coming and you may have to top off CH again. But that is a better solution than ruining your plaster finish with a low CH level.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Aug 2010
    Dallas, TX
    4,052
    I am right there with you, we are being bombarded with rain up here too. I had just added 50 lbs of calcium myself, and now I watch my pool overflow it out.
    Lower calcium for a few more days isn't going to be the end of the world. I'm waiting until Saturday, then I'll test and correct. They say the rain should end up here sometime then.
    Sure, put the tabs in since your CYA is low, your pool is overflowing, and your SWG doesn't work. Not a thing wrong with that idea.
    Quote Originally Posted by mikemass View Post
    Have you seen the news regarding how much rain Houston is getting? Adding CH right now would be a waste IMO. He can make it to the weekend.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by RobbieH View Post
    I didn't realize it was that drastic. I've been more concerned with the early heat wave in the Northeast. What are we talking? Over 3" a day? Yes - I am not about tossing chemicals (and hence $$$) down the drain. But a 120 CH is quickly going to sub 100 if you guys are getting that much rain. I would be very concerned with my pool's surface at that level.
    Aug 2010
    Dallas, TX
    4,052
    Some areas are getting in excess of 7" per day. We had a line come through (during the constant light rain) that was 3" in an hour. Rivers are several feet above flood plain and haven't crested, people are being killed by flood waters, the works. It is excessive.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Holy cow - Well pool issues are secondary in that case. Stay safe out there. That's more of a concern for the time being. I wasn't aware.
    Jun 2014
    15,221
    Everything is fine here in Texas. Just a drizzle. No worries.
    Aug 2010
    Dallas, TX
    4,052
    Amid deadly floods, Texas' Brazos River crests at record 54 feet - CBS News
    That was on 5/31, more rain today and they are predicting it will go over that.
    Oct 2015
    THE WOODLANDS, tx
    65
    Yes we were among the lucky ones that got 7-8" an hour! I'll go ahead and order the calcium. It'll probably take a few days until it gets here. I'll be ready when it's time to add the calcium. Thanks
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Good luck to all our Texan Members. Stay safe. I can't believe these pictures/articles.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    You can also switch your chlorine method to cal-hypo hypo for a while, each lb will raise CH by about 3ppm. I have been considering this myself but I haven't done the math to compare the costs.
