Thread: My pool rebuild
    May 2016
    Indianapolis
    9
    My pool rebuild
    This is my almost finished pool update. This is my 3rd swim season with this pool. We needed to install a new liner this year so we did some other improvements while it was empty. I added more cement around the pool and coated everything so it was all the same color. It only had the standard 3' oval. I installed all new plumbing (the skimmer was cracked so I just replaced all the flex pvc with hard pipe while everything was dug up). I build a pool house for the equipment and large toys and a place to change. I am currently building an automation system for the pool equipment, so I am also using the pool house for that also. I have a few trims here and there on the pool house to finish then this is done.
    Here is last season
    14,000 Rectangle inground vinyl liner, Hayward S220T sand filter, Jacuzzi Magnum 2hp pump, Hayward Universal h150 natural gas heater, Hayward CL200 chlorinator
    Jun 2014
    15,059
    Re: My pool rebuild
    That's some fine work and impressive DIY skills. Very nice!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: My pool rebuild
    Wow! Lots of good stuff there! Nice Pool!
    Casey's Avatar
    SW PA
    10,428
    Re: My pool rebuild
    Fantastic!
