Thread: Found my issue
    May 2016
    MD
    195
    Found my issue
    Thought everything was good. was passing the OCLT till last night. FC dropped by 4. I took off the light fixtures and sure enough... lots of algae. scrubbed em clean, so it was easy to remove. took the lights out and sat them on the side to dry out. neither light works and have water in them... guess the rubber seals have finally failed. it is a 20 year old pool.
    guess i need to slam... but since i was able to scrub em out and it isn't sticking.... makes me wonder?? to be safe i guess i should... but maybe will try to pass the OCLT tonight and slam tomorrow... as the bottom sucker and filter will take the loose stuff out out soon enough.
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Jun 2014
    15,174
    Re: Found my issue
    Good find! We mention light niches all the time but owns are hesitant to remove the light and check. Good you did it.
    May 2016
    MD
    195
    Re: Found my issue
    I was always worried about that being a problem... thought they were sealed in there so water couldn't get in... i looked up on you tube how to do it... one screw and pull it apart... the seals are all worn out... not sure i can really ever use them again...
    Jun 2014
    15,174
    Re: Found my issue
    I would replace it if you can. Even though water is supposed to fill the niche behind the light to keep it cool, periodically replacing the seal is a good idea.
    May 2016
    MD
    195
    Re: Found my issue
    Nice. Got a 12.5 last night and a 12 this morning FC that is.
    Turns out the DPD tablets aren't as good as the powder... seems like it comes up with 1/3 less chlorine then the powder...
    They did sit around all winter... guess they go bad even though wrapped?
