Results 1 to 20 of 20
Thread: Stain ID Kit Results
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    I have brownish-yellowish-white streaks on my vinyl liner. I tried the vitamin C test and it successfully lightened the stain. I decided to try out the Jack's Magic Stain ID kit to confirm what I am dealing with. It took over a week to receive the kit (special ordered to Canada) and was pretty excited to get it going. All of my ranges were on target for testing. As the stains aren't easily accessible to the surface, I filled a nylon with the product and placed it over a part of the stain as suggested. The powder didn't really dissolve and ended up trying to pour it over the stains. Overall, it was a bit of a disaster and do not feel any closer to confirming the stain ID. The 1st test - Iron, Cobalt & Spot etching stuff "seemed" to be the best, but I think I basically threw my $30 down the pool drain. I'm feeling a bit frustrated.
    Since the Vit C Ascorbic Acid worked --- any suggestions on bypassing another test kit and getting straight to a product? I'm wondering if I should just go for the Iron, Cobalt & Spot Etching Stuff and cross my fingers? I've also read favorable reviews on the StainFree product. I'm trying to get my "pool legs" but don't feel cut out for this stain ID test. Please help a girl out - I will get this one day (I hope).
    (Edit: I also tried a trichlor puck - the stain does not seem to be organic)
    Thanks!!
    16K IG Vinyl, Hayward Pro Series Pump, Sand Filter, Turbo Cell TCell 15, HaywardSuper Pump and 2 more pumps for for Slide, Waterfall, Powerfall, Hayward TigerShark cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Stain ID Kit Results
    Well, that is a bit of a bummer. But, yes, you can move straight on to this, Ascorbic Treatment to rid Pool of metal stains
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Ok thanks! Would the Jack's Magic Purple Stuff be a good choice for a sequestering agent? I'm totally up for suggestions - I just noticed Jack's seems to be a popular one here.
    DFW, TX
    24,483
    Yes the purple is good for saltwater pools. Jack's makes good stuff.
    Have you seen this article? Might also be handy, Pool School - Metals in the Water and Metal Stains
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree the AA treatment is a good next move, although I prefer the variation on it where you first add Hydrogen peroxide to quickly eliminate all FC and start to work on the stain before adding the AA, otherwise is there is even a little chlorine left in the pool when you start it will quickly consume the AA before it can lift the stain. As a rule of thumb common dollar store / drug store hydrogen peroxide neutralizes FC at the same rate that common 8.25% bleach adds it. In other words a gallon of drug store 3% H2O2 removes about the same number of ppm's as a gallon of bleach adds.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Again, thank you. The initial dose (per the product instructions) for the purple stuff is 1 quart per 10,000 gallons - should I anticipate needing just under 2 x 32oz bottles of purple for the ascorbic treatment (not including the regular maintenance afterward) - did I understand that correctly?
    DFW, TX
    24,483
    Yes, that is good with a little cushion for adding some extra if needed.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    And in planning ahead-- would it be fair to assume that the pool will be out of service for about a week or so until rebalanced, or do you think I should allocate more time for this process?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    When I did mine due to iron filings getting into the pool and rusting when the new roof was installed, the entire process was done overnight.
    DFW, TX
    24,483
    Just a couple of days, depending how slowly you want to raise FC afterwards. Day 1 treatment, day 2 start raising FC about 1 ppm per hour until you get to and hold minimum for your CYA, Chlorine CYA Chart. Then you can wait until, the next day and do the same to get to target level. Or go a little faster if you want.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    I'd sure like to pick up the recommended Ascorbic Acid product that was linked above in the how-to but am buying the AA in Canada. Does this product look acceptable?
    ASCORBIC ACID POWDER (1 lb (454gm)): Amazon.ca: Health Personal Care
    Edit: Ok the potassium, salts disclaimer is looking a bit sketchy? Anyone know where to get bulk AA powder in Canada?
    JoyfulNoise's Avatar
    May 2015
    13,191
    Just remember that sequestrant use is not a "one-time deal". You must add the sequestrant and then keep up the maintenance dosing as chlorine breaks down sequestrant over time. People often overlook that part and then they come back here angry the AA treatment didn't work or wondering why their stains came back.
    Do you know why these stains showed up in the first place? Do you have fill water from a well with metals? Is there a heater in your plumbing loop going bad?
    You need to understand the source of these metal stains and either eliminate them or mitigate them as much as possible.
    Matt
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Copy that, I will stock up on Jack's Purple. Not sure about the stains. We moved in and inherited a room full of bioguard chems and most, if not all of the stains were already on the liner. I very recently came to the TFP site and am now all stocked with test kit, muriatic acid, etc and am moving forward. Is there an easy way to know if a heater in the plumbing loop is going bad? And I'm on city water.
    DFW, TX
    24,483
    No, not really. The only obvious sign that it is bad is a leak!
    If the stains are copper there are 3 likely possible sources copper based algaecides, copper based mineral sanitizers or low PH, 7.0 or less, eroding a copper heat exchanger in a heater. If you know the source and eliminate the source then you can lift the stains, sequester them and reduce the copper content through a series of partial drains. And not have to sequester or worry about metals stains anymore since your are maintaining your pool TFPC style.
    If they are iron stains then the most likely source is the fill water.
    But, we know how the stain ID kit turned out. Can you look up the most recent water report from your water provider? City, municipality, water district, etc? Ours posts an annual water quality report online with test results.
    You can try to look at the heater manual for that model to see if it has a copper heat exchanger or a titanium exchanger.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Ubrucen, I just want to add that you might even find the Jacks purple alone clears the stains. Eg. In a salt water environment with low-ish iron but faint step staining, it lifted them entirely.
    But in your case, with possible historic stains, the AA will be the most sure fire. Just remember that the AA lifts the stain, but its the sequestrant and the maintenance of same that will control NEW stains coming back
    With saltwater, sometimes mild iron seems to come from the salt itself. It will also help to make sure you control your ph as high ph causes metals to come out of solution. So aiming for 7.4 ish for swg may help.
    For AA these guys say they ship to Canada: Pure Ascorbic Acid (Vitamin C) Powder in Bulk | BulkSupplements.com
    PS I like Issac's suggestion re neutralizing the FC because that way your not riding low FC levels as long in terms of days. If you do the AA treatment, you'll find that you'll want to bring the FC back up with liquid chlorine until you get it to hold where you want it before turning your Swg back on, suspect. AA will fight it at first until the fresh FC beats the AA
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    thanks very much!! I have 3 bottles of bioguard polyguard algaecide (30%) in our pool storage. Can this be used in place of "polyquat" (I believe the recommended is 60%)? And if not is this polyquat a pretty standard pool store product that I could acquire in any brand?
    I'm sincerely grateful for everyone's assistance. I couldn't do this without you all!!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    My understanding is that it needs 60 in its name to be the TFP recommended product...but unfortunately, I can't explain why or comment as to whether the 30 would work
    Most important thing is to ensure there's no copper in it.
    Helpful Links:
    DFW, TX
    24,483
    According to their website it is metal free so it should be ok.
    From their website
    Polygard Concentrate
    BioGuard Polygard Concentrate is a non-foaming polyquat algae preventative and algaecide that is excellent for use in pools with attached spas, fountains, or jetted returns
    600g/L polixetonium salts.
    Non-foaming.
    Metal free.
    Effective on all common algae types.
    Works with chlorine or bromine.
    Classified as Non-Dangerous Good
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    I've finally got all pieces and am getting started! A few questions.
    1)Does it matter if there's a bit of dirt/ some bugs on pool floor? It's not a huge amount and would prefer to get going but will take time to vacuum if it's important. 2)With the hydrogen peroxide, should it simply be broadcasted into the pool and should I wait a certain time before measuring chlorine? Will it take effect quickly?
    3) the arm & hammer soda wash - should that be measured out about the same as you would borax?
    4) oh and the polyquat- can/ should that be added before balancing ph and can it be added right before hydrogen peroxide?
    I'm excited!
  20. Back To Top    #20
    DFW, TX
    24,483
    I would net out the bugs or big stuff just because there won't be any chlorine in the pool for a bit.
    Pour the hyd per in front of a return pump running, I believe it works quickly, not sure, I would test in 15 min.
    Use Effects of Adding Chemicals down lower in Poolmath to calculate the soda ash.
    I would add polyquat right after the hyd per.
    Good luck!
